Rennch on YouTube
Show Me Your Oil Cooler (Front & Fender) Mount Fabrication
Along with the 3.6 install I'm doing, I'm going to need to mount a couple of coolers on my 69T. It has an RSR front bumper and flare. The car hasn't had a fender mount or a front mount since I've had it.
I have hard lines to the front fender, A Setrab cooler and an RX7 Cooler that's been AN Adapted. The current plan is to mount the Setrab in the Fender and the RX 7 in the front, in series. I would love to see pics of the fabrication you did to mount your cooler. I don't have a welder at the moment, but I could probably get one. If there are already built setups, please point me in the right direction for the brackets. Thanks!
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
Rennch on YouTube
Happy Monday.
Matthew - drove Nurburgring with wipers on and no rain 1969 911E SOLD ![]() 2002 996 Cabrio 1995 993 Carrera 4 SOLD 2004 Land Rover Discovery II G4 Edition (Sold )
Since I happened to have some pictures on my work computer...
I took a Setrab cooler originally intended to go in the fender, cut off two of the mounting tabs, bought some fittings, brackets and hoses from Chuck at Elephant Racing and mounted it in my front bumper opening. Pretty straightforward and very low budget (from a fabrication standpoint) but it works great. Obviously I did not cut the tub behind the cooler for better airflow, etc. and it has been perfectly fine. Oil temps are shockingly cool. The last picture is about as high as the oil temp gets during ~90F outside temps as long as the car is moving... ![]() ![]()
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Rennch on YouTube
Funny Mike...yours were the only photos I'd previously saved. Thanks for posting again.
Here is another for an RS type front spoiler.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
A Setrab..
![]() ... ducted thru the hood
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Rennch on YouTube
Did you fab that bracket Magnus?
Yes, had to cut of the top mount on the cooler
A few pics of cooler mounting - function over beauty
Welded in bracket on driver side - fabricated center bracket - curved body behind center cooler. Air flow ducting is essential. Don't use fine mesh screen for air duct holes - need 1/4" or 1/2" just to keep the big rocks out. Regards, Roy T ![]() ![]() ![]() ![]()
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
The early cars don't have big bumpers so not much room for a front cooler. Here is how I added a gigantic one to my 73.
Here is the build thread. Oil cooler starts on post # 210 Saving a 73 from the crusher... ![]() ![]()
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html Last edited by wayner; 07-07-2015 at 04:05 AM.. |
Setrab cooler which I mounted in my CTR bumper:
Certified User
You could always fit a standard oil cooler to the crankcase ...
Bill 1988 Carrera - 3.6 engine with ITBs, COPs, MS3X 2024 Macan S Day job ... www.jesfab.com.au Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S |
Retro fitted an on engine oil cooler to my 964 3.6 transplant motor. That, along with a standard Carrera front oil cooler/fan, the oil temp on a 90+ deg day stays in the 200 deg range. (200-210 worst case)
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
