ninelevenick's Avatar
help - stranded!
I drove about 5 miles to make an errand. When I turn the key in the ignition, nothing happens. Lights do not work, nothing. Any ideas?
Old 07-10-2015, 04:08 PM
battery connections?
Old 07-10-2015, 04:11 PM
The irony is the trunk is stuck closed!
Old 07-10-2015, 04:12 PM
When I turn the key, the speedometer sometimes jumps a little.
Old 07-10-2015, 04:13 PM
Banned
No Battery, or not charging.
Old 07-10-2015, 04:23 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Battery cables.
Not sure about your conversion, but the +12v battery cable is available at the starter,
and the -12v battery cable is also available at the body grounding point.
At those two points you can test battery.
Gerry.
pm sent.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-10-2015, 04:25 PM
Thanks guys. Finally got into the trunk, jjiggled the relays and some wires, and she starts!
Old 07-10-2015, 04:28 PM
sugarwood's Avatar
I've read that you might try spreading the prongs of the relays to make a tighter fit.
You might also tighten your battery cables, if they are loose.
1986 Bosch Icon Wipers coupe.
Old 07-10-2015, 08:09 PM
+1 on the prongs. Similar thing happened to me once a couple years ago. Spread the prongs of the fuel pump relays. No starting problems since.
Old 07-10-2015, 09:59 PM
Good idea, guys, about the prongs. I'll have to do that.
Old 07-10-2015, 11:23 PM
ROW '78 911 Targa
timmy2's Avatar
Clean all the fuse holder connections while you are in there.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-10-2015, 11:38 PM
