help - stranded!
I drove about 5 miles to make an errand. When I turn the key in the ignition, nothing happens. Lights do not work, nothing. Any ideas?
battery connections?
82 SC , 72 914 |
The irony is the trunk is stuck closed!
When I turn the key, the speedometer sometimes jumps a little.
Banned
No Battery, or not charging.
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Battery cables.
and the -12v battery cable is also available at the body grounding point. At those two points you can test battery. Gerry. pm sent.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Thanks guys. Finally got into the trunk, jjiggled the relays and some wires, and she starts!
I've read that you might try spreading the prongs of the relays to make a tighter fit.
You might also tighten your battery cables, if they are loose.
1986 Bosch Icon Wipers coupe. |
+1 on the prongs. Similar thing happened to me once a couple years ago. Spread the prongs of the fuel pump relays. No starting problems since.
Good idea, guys, about the prongs. I'll have to do that.
ROW '78 911 Targa
Clean all the fuse holder connections while you are in there.
