Going strapless would be groundless - Where do these go? Help
After many, many months of dismantling, stripping, painting, repairing, replacing, rebuilding I am on the home stretch. "While you are there" syndrome can really get expensive when "there" is everywhere. Engine and tranny now reinstalled and I am hooking up electrical. I have two ground straps. Vinyl coated slightly longer than one foot. Wonderfully cleaned, derusted, and deoxidized. I just can't remember exactly where they go. The one from the transmission to the body near the tranny mount is in place.
Man, arthritis and memory loss really sucks. Thanks in advance. David |
Re: Going strapless would be groundless - Where do these go? Help
how about engine lid to ground
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Ron is probably right, but another possibility is alternator to engine case. One lug for M6 stud on alt. case, other for M8 stud on engine centerline, near breather cover.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
-also did a 10ga., marine wire, back-up on that one
I'm just putting mine back together as well. Mine has one on each engine cover hinge. Not sure why though. I made some up for the hood as there were none. I figure it can't hurt.
kevin
KEVIN WOOD 70 911E TARGA |
I don't know it computer cars take their computer ground seriously . I figure they should
Hello, it could be the one that goes from CDI unit mounting plate to the ground stud.
Jorge (Targa Dude) |
A little more info might help. 86 Carrera Coupe. Ground straps are flat and braided.
Did one of these go from the battery to the body? Thanks David |
Got Boost?
I think my girl friend uses strapless too, I will ask her and let you know.
"The only motivation to make you go race after race, travel after travel, is winning. The possibility that you have for winning. If you don't have that, nothing else can make you work." -Ayrton Senna- |
