DanS911's Avatar
'86 3.2 starts every time runs 1 min then dies
So... like I said it starts right up every time and idles perfectly...for about 1 minute then it just dies. I can keep it running barely with constant throttle playing around.
After about two or three minutes it clears out and runs perfectly for the rest of the day!
Put in new plugs and it seemed to be healed the last time I drove it only to do it again today
Any ideas would be greatly appreciated.
Dan
'86 911 Targa Driver
'76 911 Targa 3.0 Track Toy
46mm PMOs, 10.5/1 J&E,Web Cams, Wide Body fenders, 23mm and 30mm Hollow T-Bars, 930 Sway bars, Bilstein Sport Shocks, Plastic Bushings (too damn squeeky)
Old 05-19-2017, 06:13 PM
Check and clean idle control valve, also check for vacuum leaks once it is running smooth, take off oil cap and listen for a stumble. If it doesn't, find the leak.
Old 05-19-2017, 07:07 PM
I agree with obgyn. Do a search on idle control valve or ICV. You will see how it works and how some have cleaned theirs. I eventually had to replace mine. Pelican has new ones for about $350 IIRC.
Good luck,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 05-19-2017, 07:16 PM
Test the head temp sender for proper specs. Sounds like it's choking out.
Old 05-20-2017, 06:02 AM
autojack's Avatar
If you find it's the head temp sensor, I have a brand new one I bought from Pelican last year, which I didn't end up needing. It's in original packaging. Happy to sell it on at a discount, PM me.
Old 05-20-2017, 09:10 AM
ASE Master Tech - 35 yrs
larrym's Avatar
Exclamation 3.2 starts-dies
i had a similar problem with an '89 that had been in long storage - turned out that 3 injectors were "plugged" with fuel varnish - there is a thread about this -
3.2 starts dies immediately - all tests good
also check this
https://rennlist.com/forums/911-forum/531320-carrera-3-2-no-start-big-mystery-2.html
also - just google it
https://www.google.com/search?q=3.2+starts+dies&ie=utf-8&oe=utf-8
let us know what the solution is when you solve it
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 05-20-2017, 10:08 AM
When I had similar symptoms, it was the common problem of cracked solder joints on the DME. You may want to try tapping on the DME during this period to see if it affects it one way or the other.
Best,
Chuck.H
'89 TurboLookTarga, 433k miles
Old 05-22-2017, 05:56 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
DME Relay.
Swap out the DME relay.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-22-2017, 08:14 AM
You must narrow down the problem to fuel or electrical. When it stumbles, see if a quick shot of ether keeps it going. If so, you may have a fuel insufficiency caused by clogged injector or fuel filter. If it does nothing, I'd troubleshoot electrical issues.
Go easy on the ether...
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 05-22-2017, 08:24 AM
Diss Member
Quicksilver's Avatar
Don't swap ANYTHING unless you already have it laying around.
Test Test Test! The things I would want to test right off are:
- Cylinder head temp sensor.
- Idle Control Valve. (Cleaning it might be a good "while your in there" project.)
- Exhaust port temps on startup. (Test with an IR thermometer.)
- Fuel pressure. (Test at the left hand injector rail's test port.)
A quick search will give you how to do all of these except maybe the exhaust port temperature test. For that get the car up on stands while cold and then fire it up. Immediately get under there and start reading each exhaust port to see if the temperatures are rising evenly. Any serious differences will tell you if you have an issue to chase. A cold cylinder could be miss firing, have a bad injector, or a vacuum leak.
The issue could be with an intermittent DME issue where something is iffy until it warms up but I'd put it low on the list.
A knee jerk "replace the DME relay" was thrown out but that is really unlikely. If you are testing that the least expensive and most sure way to test is to build a DME test jumper which is just three connectors wired together. You can search on that too.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 05-23-2017, 06:53 AM
xu1997
Symptoms suggest fuel pump
Old 05-23-2017, 07:13 AM
