Struts ?
What is the easiest way to see if I have Bilstein or Boge struts in my 84 Carrera ?
Old 07-21-2015, 07:22 AM
French Import
zippy_gg's Avatar
As a rule of thumb Bilstein would be green and Bodge would be black.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 07-21-2015, 07:26 AM
I didn't add that they have been painted by PO .
Old 07-21-2015, 07:35 AM
look at the bottom of the strut, bilsteins have a roll pin to hold the insert in, where boge use a threaded collar at the top
Bilstein:
Boge:
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end.
http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html
Old 07-21-2015, 07:58 AM
Brew Master
cabmandone's Avatar
I think my Boge housings have Boge stamped in the housing. I'd have to look but IIRC it is stamped.
Old 07-21-2015, 09:05 AM
My front Boge had Boge stamped near the bottom of the strut, facing the caliper.
Old 07-21-2015, 12:10 PM
Thanks Bergo , I see a roll pin so I guess they are Bilsteins !
Scott .
Old 07-21-2015, 02:53 PM
suckho's Avatar
I need to ID my 911 SC front struts. The two photos on the left side are from my car. The photo on the right is from PP article about shock replacements. The article says that Bilstein type front struts can be identified by roll pin and color. My struts dont have roll pins and are painter black (on red primer) so the are Boge, am I right? Is there any other possibilities?
Porsche 911 SC Coupe (1982, RoW, Zinnmetallic)
Old 08-18-2015, 10:28 PM
gtc gtc is offline
abides.
gtc's Avatar
Boge
Also, if you had Bilsteins, you would have the "474" option code on the sticker under the front hood.
Graham
1984 Carrera Targa
Old 08-19-2015, 09:50 AM
