Struts ?
What is the easiest way to see if I have Bilstein or Boge struts in my 84 Carrera ?
French Import
As a rule of thumb Bilstein would be green and Bodge would be black.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
I didn't add that they have been painted by PO .
look at the bottom of the strut, bilsteins have a roll pin to hold the insert in, where boge use a threaded collar at the top
Bilstein: ![]() Boge:
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end. http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html Last edited by Bergo; 07-21-2015 at 08:00 AM.. |
Brew Master
I think my Boge housings have Boge stamped in the housing. I'd have to look but IIRC it is stamped.
My front Boge had Boge stamped near the bottom of the strut, facing the caliper.
Thanks Bergo , I see a roll pin so I guess they are Bilsteins !
Scott . |
I need to ID my 911 SC front struts. The two photos on the left side are from my car. The photo on the right is from PP article about shock replacements. The article says that Bilstein type front struts can be identified by roll pin and color. My struts dont have roll pins and are painter black (on red primer) so the are Boge, am I right? Is there any other possibilities?
Porsche 911 SC Coupe (1982, RoW, Zinnmetallic) |
abides.
Boge
Also, if you had Bilsteins, you would have the "474" option code on the sticker under the front hood.
Graham 1984 Carrera Targa |
