Odometer stopped working after I trimmed some wires
I have a 1975 911 that has a 964 engine and 993 G50 six-speed trans shoehorned into it.
When I bought my car both the electronic speedo and odometer were working fine. I tried to clean up some of the underhood wiring mess and cut some wires I believed to be connected to an aftermarket stereo. Since that night the speedo still works but the odometer does not. I am assuming I cut a wire related to the odometer but I just assumed the speedo and odometer worked off the same wire(s). Apparently not. Does anyone have any insight into what may have happened or have a schematic of the wiring for an electronic speedometer (I assume it is a 1996 speedo) that would work with my 993 G50 trans? All help is greatly appreciated. Thanks. |
I' thinking it is just happenstance that your odometer gear inside the speedo failed. As fas as I know there is no wiring dedicated to the odometer. I could be wrong, but I don't think I am.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current) 1989 911 Targa (sold) 1996 993 Cab. (sold) 1999 x2 Boxster (sold) 2006 Cayman S (my daily) |
I think it is just a bit too coincidental it happened the same day. Plus, I think my speedo is out of a newer 1996 model since it works with the 1996 G50 trans. Does anyone happen to know if there are 2 different wiring circuits for the odometer and speedometer.
Rather than guess at all of this, take a look at the part number on the speedo and figure out what year it's from. Then have a look at a wiring diagram for that year.
I've never seen a speedo with separate wires to the odometer, but at least you'll know for sure. JR |
You could also trace the wires from the back of the speedo to confirm they are still connected or cut.
Or, if possible, borrow a '96 speedo that you know is working and plug it in to test. Either way, you will find the root cause.
************************* Socbum '88 911 Coupe Last edited by Socbum; 07-27-2015 at 07:02 AM.. |
Good suggestions. I will try those.
