| Registered Join Date: Jun 2015 Location: Foothill Ranch CA
				Horn not working ?
			Hi Guys,   My horns on my 80 SC we're working fine until last night when I removed my steering wheel to install a bushing sleeve.  Once I reinstalled, no horns.  I know I plugged the wire back to the horn button correctly.  What else could it be ?
|  07-25-2015, 07:46 PM |
| Been here a while Join Date: Apr 2004 Location: East coast, west coast, typ. 35,000 ft
			Is this one of Mitch's bushings?  I had this problem.  It turns out the factory steel part on certain years of cars if the only way that the steering column grounds to the chassis. John walker suggested a piece of spring steel on the column in the smugglers box, but instead I installed the factory steel bushing out of a 928 available thru our host, and it works perfectly.
|  07-26-2015, 03:04 AM |
| Registered User |
			If you don't hear the relay clicking when you press the horn button, then definitely go back to the steering wheel and make sure you're getting continuity to ground when you hit the horn button (with the battery disconnected, this is easy to check with a multimeter).  If you do hear the relay click, then the problem is between the relay and the horns, or the horns themselves.  In my case, I swapped the steering wheel and the next day my horns weren't working-- just being rational, I assumed problem was with the wheel, but it turned out that my horns themselves were dead...
|  07-26-2015, 03:40 AM |
			Yes, I did use Mitch's bushing.  Works flawless besides the horn issue.  Anyone else have this problem ?
|  07-26-2015, 05:11 AM |
			Do this.  Try removing the key altogether.....I'll bet your horn will work with the key off and removed....an important part of this is to actually remove the key, as once the key is fully inserted, it breaks the ground thru the steering lock tang that's part of the ignition switch.
|  07-26-2015, 12:25 PM |
| RETIRED |
			Yep, the ground.  "Horn not working, watch for finger"  One of my favorite bumper stickers.....
				__________________ 1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel | ||
|  07-27-2015, 04:16 AM |
			fixed it,  it was the horn "tab" on the hub not contacting the wheel properly.......
|  07-27-2015, 05:18 PM |
| Bland |
			Get one of these stickers, problem solved...
				__________________ 06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche | ||
|  07-28-2015, 01:38 PM |
