spark plugs wires
need to ask you professional guys a question. I am checking the wires and could not get them to show good. the wire checks good but the plug end and the distributor end also would not check at all. Is there a reistor are somthing that blogs me from checking continunity. How do I check them If there a risistor
Old 07-29-2015, 06:59 PM
ROW '78 911 Targa
timmy2's Avatar
Put your meter on the K ohms range. Should be 3-4 k ohms IIRC.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-29-2015, 07:50 PM
Checking continuity in ignition cables is useless since it does not tell you how they will perform in normal operating conditions of voltage ranges of at least 15kv. A better test would be to spray plain old water on your cables at idle.
Old 07-30-2015, 01:30 PM
wwest's Avatar
"The wire checks good...."
End to end the wires should read a minimum 1500 ohms (nichrome spiral), less than 4000 ohms for carbon (think ground-up pencil lead) impregnated fiber.
You should not be using solid wire that will measure in the milliohm range.
The distributor contacts should all read infinite to each other, no physical metal contact, HV jumps across open distributor gap simultaneous with jumping sparkplug gap.
Old 07-30-2015, 01:42 PM
