Cat bypass with o2
1987 02 sensor frozen no need for cat, what can I expect,installing Brush bypass
Old 08-07-2015, 01:45 PM
Hi
Targa Me's Avatar
will probably run rich.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 08-07-2015, 02:02 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Expect a little less back pressure. A touch more favorable rumble. Maybe a few ponies.
Make absolutely sure flanges are sealed upstream of the sensor. I have used two factory gaskets with $8 muffler paste from the local store.
1981 911SC Targa
a lot more stink at start up. i liked the sound better with the cat bypass. i thought i could feel a little more oomph, but now having gone back to the cat for smog, i'm thinking no noticeable difference...
1983 911SC Cab
Old 08-07-2015, 02:58 PM
Reiver
Reiver's Avatar
A bit more noise and a bit more smoke/fumes on start up. You might get a few HP but only at WOT...most confuse the noise for HP.
If you notice a big difference it's because your cat has partially failed and is clogged.
You will lose a big hot spot next to your cam cover tho.
De Oppresso Liber
Strength and Honor 5th Legion
Old 08-07-2015, 04:10 PM
