Fuel Pump Runs Constantly with Key in On (but not started)
Per the title, I recently got my SC back from the shop and it is running great. However I noticed something odd. When I turn the key to On, but not yet to Start, the fuel pump runs. I expected this. But it keeps running and running.
If I recall properly, it is supposed to stop after a few seconds, probably when fuel pressure is achieved. Am I remembering correctly?
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. |
Member 911 Anonymous
Isn't that normal to keep the pressure on until shut down? I think what you are hearing is the pump ready to go. My new PAG pump started to make noise after 2 years. :-( put old one back quite as a whisper.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Ok, I won't worry. It is just kind of weird to hear it running and running and running. I guess that means I should stop thinking about it and start her up!
I could be wrong but others will chime in I'm sure :-/
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
If the sensor plate green plug is off, the pump runs.
Or the cold start injector and the air flow connectors are mixed up on the front of the fuel injection.
Bruce Last edited by Flat6pac; 08-24-2015 at 12:21 PM.. |
I have had my 3.2 for 5 years and when I turn the key to on I hear the fuel pump. Stays on, does not go off.
Sure enough, I reached back and the cold start injector connector had nothing on it, and the one on the distributor (pressure sensor?) had the injector's wire. The other wire was hanging loose.
Obviously if you don't know what you are feeling for and don't take off the spaceship boot, you can't see what's going on, and SCs are weird, so I forgive the shop. I switched 'em back with one hand in 2 minutes before I rolled out to work. Now she starts more easily (amazing what the injector will do for you!) and has no constant FP running. I'll link a picture for Nick and anyone else who might come by.
Here is the view from the front. The throttle body and spaceship boot have been removed so you can see the two teal connectors.
The one on the upper right is the sensor from the fuel distributor. I believe it tells the FP when pressure is reached, to turn off the FP pre-start. The one in the center is for the cold start injector. It sprays fuel into the airbox and to the cylinder heads to get extra gas for the initial start. ![]() Here is the view of the back, with the CIS system out of the car on my workbench. You can see the fuel distributor connection in the center, and the cold start injector down on the right. I believe the cold start injector connection is an "output" and the fuel distributor connection is an "input" as far as the systems are concerned. So swapping them results in neither having an effect. You'd have trouble starting when cold, and your FP would keep running.
El Duderino
OsoMoore,
When I first got my SC I took it to a shop because of all the CIS issues. Same thing happened as you. I posted the same question and John Walker posted the same answer. I plugged the sensor plate wire back it and my CIS issues I paid the shop to fix came back. I suspect this is a poor man's way of overcoming starting issues by causing the fuel pump to run and pre-pressurize the fuel lines before cranking. I'm not saying the shop did anything unscrupulous in your case -- it could've been an accident -- but I certainly believe it to be the case in my situation. It is my understanding that in a rollover event, that connection also is designed to shut off the fuel pump so it is important to have it connected and fix the real problem.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
Did some more reading - the sensor is actually called the fuel pump safety switch. And as you can see in my picture, it is actually on the air sensor plate assembly.
In any event, it is now quicker to start and doesn't idle the FP nonstop. Now if only the sun would come back out!
El Duderino
Glad you are enjoying you car again!
Outstanding!
