Fahren mit dem Wind.
"Flashing" question
I've noticed that drivers of other 911s heading toward me on the road flash their lights in recognition of a fellow enthusiast. My 1983 911SC does not let me flash the lights with the bright/dim headlight switch on the steering stalk so I have to do the wave. My question is, when did this feature first appear in 911s. Might be useful to help "date" a passing car as all I saw this morning (near Fairport, NY) was a black coupe with a bit of a tail. I know it wasn't an early 911 but wondered if it was a fellow SC driver. The light flash might place it later. Just curious!
Keeper of the 1983 911SC Cabriolet Registry (http://911sccabrioletregist.freeforums.net) Caregiver to: 1983 911 SC Cabriolet - Fahern mit dem Wind. (Moss Green Metallic over Champagne and Brown Leather) |
I think your's should be able to flash by pulling stalk toward you. I had a '78 SC for 17 years and I could flash my lights. I suspect that stalk design was consistent at least through 1989.
Dave 1985 Factory Turbo-Look Coupe 2011 Cayman S 2012 Audi S4 |
Hoss is correct. Both my 70 and 88 flash by pulling the stalk rearwards against a spring. yours should too.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
As mentioned, they all are supposed to do that. Porsche didn't put relays on their headlight circuits so all of the current for the light flows through the switch. They tend to fail, as a result. Remove it and look for the various threads on how to fix it. Or, replace it with a new one.
JR |
Ok, that's good to know. I had repaired the turn signal on this unit so it's likely the flash needed repair too. Just when I thought I was completely sorted! Gives me something to look forward to this weekend!
Undocumented User
Some guy in Massachusetts was driving an SC cab, when I passed him I flashed to say hello and didn't get a flash back. How rude.
Troll Hunter
That function has been around since Moby Dick was a minnow. Even the 356's have it.
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
Ha ha ha McLaren-TAG! good one.
I know my 356 had it, I don't recall if my 70S does, another thing to check when I get home. I need to make this right, I can't continue being rude!
Well, turned out to be an easy fix. I removed the switch and scrutinized to see how it works. Pulling back to flash should close a pair of contacts (you can see them from the front of the switch through a little opening) but they were not closing completely. I carefully "repositioned" the contact (i.e. bent it with a small screwdriver) and now the flash works properly. No more rudeness on the road!
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Flash.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Too funny!
