drag racing the short bus
dd74's Avatar
Proper way to warm up an SC engine?
I've been letting my rev at 2,000-2,100 RPM for about five minutes, then while driving, I slowly ease down the hand throttle until it operates smoothly. Is this correct or incorrect? Do others use another process?
Thanks.
The Terror of Tiny Town
Old 11-18-2002, 04:49 PM
I start the car, idle for about 30 seconds and pull away. I keep the RPM's down to about 3,000 - 3,500 until it hits the first tick on the temp guage.
What are you doing with a hand throttle on a SC motor?
EDIT: I noticed you are also from So Cal. I would imagine that those in the colder (read snow) parts of the world may benefit from a longer initial warm up.
Old 11-18-2002, 04:57 PM
D idn't E arn I t
RANDY P's Avatar
ditto that. Fire up, as soon as the idle stabilizes, pull out and drive easy. When full hot then have at it with the throttle.
Excessive cold idling is hard on the motor, minimize your cold start time and drive.
rjp
In the movies only bad guys sleep in king size beds.
Old 11-18-2002, 05:01 PM
Hand throttle??
Anyways, I start the car, put my seatbelt on, check the mirrors and drive off, taking it easy until warm. From start up until pulling away is probably around 10 seconds.
Idling for 5 minutes before taking off is excessive and a waste of time, IMO.
Old 11-18-2002, 05:02 PM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
Not an SC owner...
But I start the car...
select the best song on my CD...
And roll
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 11-18-2002, 05:11 PM
dd74's Avatar
re: hand throttle
My engine's a transplant into a 1974, which originally had a 2.7 with a manual choke (hand throttle). Got rid of the smog equip and other electronic/computerized stuff when the motor was installed.
Old 11-18-2002, 05:29 PM
Team California
speeder's Avatar
Agree w/ the others. What, you don't believe in warming up the transmission, CV joints, etc.?? You're wasting fuel and polluting the environment, if the engine is running the car should be going somewhere. The recommended procedure is to start the car and drive easy until everything is warmed up, they warm up just fine while moving. This especially goes for -20deg. weather, (I am a native Minnesotan).
Denis
Old 11-18-2002, 07:13 PM
my sis lived in germany for a while. big tickets for warming up. start it and drive easy. ps i cheat with block heaters. ha
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 11-18-2002, 07:39 PM
PORSHIN's Avatar
Send a message via AIM to PORSHIN
Porsche advises against warming up before driving. Bad for the engine. It will among other things cause carbon build-up in combustion chambers.
Rob
Old 11-18-2002, 07:53 PM
dd74's Avatar
took everyone's advice on the way home tonight
Got in, drove easy, got it warm, drove a little harder. Then got stuck in traffic with all the other idle polluters.
Old 11-18-2002, 08:06 PM
