A/C Low Pressure Post Location : 1985 911
I am venturing into my friends 85 cabriolet A/C system. While I have owned, serviced three 944 cars for twenty years, some of the 911 design mystifies me.
I have done my own a/c work with sucess. For the 911 I ask: 1. Where are the high & low ports? (denso compressor..on the compressor itlself, I thought the rear facing port was low and the forward high) 2. Where is the receiver drier hiding? 3. Where is the low freon cut off safety valve? (in case I need to bridge it if there is zilch for freon so the compressor clutch will engage) Thanks in advance folks. Patrick |
Fleabit peanut monkey
Dear Lord. Brace yourself, Patrick
1981 911SC Targa |
Banned
Patrick, Nippodenso compressor ports are marked D (discharge = high side) and S (suction = lowside), but regardless, the highside port has the hose connected to it that goes to the tail condenser.
The receiver/drier is in the front left wheel well, backside of wheel. No OEM pressure switch, but if one was added at some point, it would either be in the vicinity of the high side port on the compressor (or inline with the short section of hose there), or in the vicinity of the receiver/drier. |
Charging ports, converting to R134a.
Nostalgic AC - R134a Charging Ports - Fittings & Hose Kits 7/16" R134a high side adapter, pressure switch, 398 PSI compressor cutoff Nostalgic AC - Binary Switch w/ R-134a Discharge Port 7/16" - AC Pressure Switch - Oil, System Flush & Switches RED DOT Trinary pressure switch, 325 PSI compressor cutout. Extra element for fan/louver control. Red Dot Corporation | Mobile HVAC | |
1988 Carrera
70 911T Sold 81 911SC Coupe84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code |
398 psi. off is too high Last edited by kuehl; 08-20-2015 at 09:49 PM.. |
