| Registered Join Date: Mar 2015
				Help identifying mystery switch
			Could someone help me identify the function of this push-pull switch beneath the oil gauge on my '72? The owner's manual doesn't label it on the control layout diagram. Is this something someone added long ago? I haven't attempted to trace the wire yet. Hoping someone knows the answer. It doesn't seem to do anything.    Last edited by 422flat6; 08-22-2015 at 05:56 PM.. Reason: Fix image rotation, ok maybe not... | ||
|  08-22-2015, 11:46 AM |
| Registered |
			Not factory.
|  08-22-2015, 12:20 PM |
			I suspected it wasn't factory. It's definitely a vintage switch though.  Some disassembly reveals that when pushed in, it connects the brown wire to the brown with white dots wire (the two poles in the foreground of the photo) and when pulled out it connects the two red with black dots wires (the poles in the background) The wires look factory. Without tearing the dash apart it's hard to see where they go. Any ideas?   | ||
|  08-22-2015, 12:57 PM |
| Registered Minimalist |
			Perhaps a license plate light 'stealth' switch. :-)  When did they start putting license plate lights on?
|  08-22-2015, 01:07 PM |
			Haha interesting guess. It doesn't affect the license plate lights though so that's not it. My car has no fasten seat belts light/buzzer. When was that added? I can't imagine why you would need a switch to disable that though.
|  08-22-2015, 01:20 PM |
| 83 911 Production Cab #10 |
			if the part # finish with "007", it the Ejection Seat Switch...
				__________________ Who Will Live... Will See    83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger | ||
|  08-22-2015, 01:34 PM |
| Registered Join Date: Apr 2005 Location: outta here
				 | Quote:
 The wiring in your pictures is factory, so that switch probably does something... JR | ||
|  08-22-2015, 02:35 PM |
			People used to put in switches that would disable the car from starting, so that's one likely possibility.  You might track the wires and see if you can figure out where they go. JR | ||
|  08-22-2015, 02:46 PM |
| ROW '78 911 Targa |
			Rear wiper? Wire colors seem correct for one.
				__________________ Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. | ||
|  08-22-2015, 03:13 PM |
			Ah, yes my COA does show the rear wiper option but it's been removed.  I forgot about that!  There's a really good chance that's what it is.  Thanks!
|  08-22-2015, 04:59 PM |
			I think he nailed it.  I think that's a factory switch, too.  Not many cars from that era had that option. I think that's the same switch that Porsche used on the RSR to switch the ignition systems. JR | ||
|  08-22-2015, 05:13 PM |
