weekend wOrrier
2 window support fail questions
Hello,
I'm sure this is about as common as a "what type of motor oil should I use" question, but I don't know the correct terminology to do forum search on the support thingee- so please help!!!
As I'm sure has happened a 1000 times before to everyone else on the planet, the window support bracket? (whatever it is called) came loose from the window. The window fell. I was on the road, and the window lift arms shook/scratched all up against the window tinting as it raised the window armature and as it rattled on the drive home.
So anyway- I pulled it all apart... and the questions are (drumroll please....)
1. How do you reattach the bottom bracket to the window properly? Press fit? Glue? New rubber seal?
2. How does one go about fixing/ replacing the scratched tinting? I don't know if that's factory tinting or not- but it seems to be a heavy and professionally done tint.
Arghhhh.....
Thanks,
Ron
Old 08-29-2015, 07:07 AM
