Turn signals out after center console removal
I have an '86 Carrera Coupé. Just replaced the shifter cup bushing and did a rebuild of the shifter housing. I removed the shifter center console (AC/Rear glass heat/Hazard lights/Auto lock button) and replaced successfully without issue. Only thing is, I did a function check of everything an noticed the turn signals (both right and left) don't work. All bullets in the fuse panel appear to be ok. Any help?
El Duderino
On my '83 the turn signal and flasher systems are inter-related. Guessing it's the same or similar for '86.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
Check the 6 pin plug (turn signal stalk harness) under the dash vicinity of the steering column - maybe it got bumped?
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Recreational User
The hazard switch in the console uses the turn signals for flashing, so I'll bet the switch must be improperly connected or the connector in back of it is not completely secure. You may need to remove that switch and inspect it. But first, check the fuses for the turn signals just to make sure they're not blown.
Roger, thanks fort the input, boys! Didn't know the hazard and turns were connected.
Weekend Mechanic
The hazard switch is an integral part of the flasher circuit. I found this out when I had my center console out. The flashers didn't work until I reconnected the hazard switch.
86 911 Carrera Targa
Hazard switch is were the issue is most likely.
