Exclamation Rear window heater element
Does anybody know does the rear window heating element wires come in the new seal (my new one has no wires) or do i need to pull the old wiring out of the old seal and somehow put it in the new seal ???
Thanks for you help.
Old 08-31-2015, 05:12 PM
Gunga Galunga
doublebuffle's Avatar
No. You will have to put it in yourself. Pain in the butt. I skipped that part.
Also, you have a lot of "use the original part" advice coming. I did and it worked well.
GL getting the window back in. There's no youtube video.
Old 08-31-2015, 05:18 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Pull old wires carefully, it is mostly grunt work. Do mark locations, take pictures too!
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 09-01-2015, 01:43 PM
tobluforu's Avatar
Delete.
Old 09-01-2015, 01:48 PM
The hot/signal wires from the rear glass disconnect from within the engine bay itself, down behind the relays/fuses on the left hand side. The ground wire(s), on the other hand, are bolted to a bolt near/behind the fuel filter. The wires, plug, and ground connection are much too large to easily fit through the grommet that lies between the engine bay and cabin. I ended up cutting and lengthening all lines from within the cabin to both repair prior shoddily done work (only soldering and heat shrink tubing for me) and to provide some spare slack next time work has to be done in the area.
If I had to do it all over again, I think I would've actually created my own plug set (male and female) to provide a quick disconnect from within the cabin.
Thanks,
Matthew
Old 09-01-2015, 01:55 PM
