<insert witty title here>
leaking engine oil cooler?
I just removed the engine oil cooler to replace the three seals and found a whole lot of oil gunk at the bottom of where it mounts. Would this indicate the cooler itself is leaking, or more likely seals? Something is leaking around there - the heat exchangers are always wet. But I'm also replacing the flywheel seal which was leaking, and there's a slight possibility the thermostat seal might be leaking, and that might be weeping down there.
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
RETIRED
Radiator shop and have it pressure checked.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I would think it is either the seal, or the thin case casting issue.
Case imperfection - leave alone or JB Weld?
Ed 1973.5 T |
are you sure that this is not the breather cover leaking down Christien ?
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
See the little notch in the case behind the cooler on the le ft. Clean it up, wire brush it and add JBWeld. That's your leak
Now, on the outside under #6 youll see another match to that one, clean, wire brush, and JB too. Bruce |
Mine is doing the same kind of thing, my Indy is convinced it is the seals. I agree, pressure testing the cooler would be an idea way to test it...after cleaning it up. Mine will be getting this treatment starting tomorrow.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
One of the great things about having carburetors with rain hats is that that area of the engine is very easy to see and access, so even if it did turn out to be one of the triangle of death oil leaks, they're all easy fixes with the engine in. I've replaced the flywheel seal and I'll be replacing the oil cooler seals when I reinstall it.
So I took the cooler into a rad shop today to have it pressure tested - he said he didn't have the right equipment and would have to fabricate a steel plate to cover it, or order stuff in. A week or 2, $100 or so. Does this sound right? I mean, I could probably replace it with a known-good unit for not much more than that, and get it here faster.
Are these things prone to leaking? Or should I just button it back up and hope it was either the seals or the case crack, which I JB Welded a few days ago?
You can always call waletail and get it same day . I know he has them.
Project Addicted
Only the upper 2 holes need pressure. He could plug one and use a rubber nipple on the other. You could do this at home if you have a compressor and a bucket of water.
Jon 1966 912 1976 911 3.4 Backdate Project 1986 944 |
How would I rig up something to inject air into one of the holes? I've searched around here for a DIY pressure tester and didn't find anything.
Member 911 Anonymous
HF has a vacuum/pressure tester cheap and it has rubber fittings.
Just get some piece of bike tires, plug one side and start pump, if you have a leak the gauge will bleed out. To find the leak sub-merge into water. $100, WTF??? for not have equipment he should have, really??? I don't you should be re-tooling a shop.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Sure doesn't look like an oil cooler or seal leak (a seal leak would show oil at the top of the cooler). I think it's the thin casting problem, that you've already fixed. I'd just bolt it back on with new seals (the red ones if you can find them, or the green ones if you can't) and I think you'll be ok.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Stomski racing makes a great oil cooler tester.
Agree the leak is the casting. Bruce |
oil cooler repair with jb weld?
hi peeps.. not to hijack this thread.. but i have same issue with a front mounted setrab oil cooler in my race car.... its a slight leak some where i drained it and took it to 4 places today seems nobody does radiator repair anymore... at least not in philly region..
if i find the leak with air and water dip can i actually repair it with jb? i thought it would have to be soldered like the old ways..its a brand new aluminum setrab. point me to some threads if you can thanks alot frank |
So any ideas on how I can make a homemade pressure tester? I've got all day tomorrow open. I can see plugging the holes easily enough, but I can't think of a way to run air into one of the holes such that it's airtight. And the guy at the rad shop today suggested as much as 50psi. I've read threads here that said 10psi should be sufficient, but really, if I'm going to the trouble to fab something up, I want to make sure my results are positive.
Not sure you can get one for $100 even used...the new part is $1200 or $1600 at our host? At least for my '89.
