adjusting valves with or without the cat on
How many keep the catalytic converter on the car when adjusting the valves on a 911 SC... New 911 SC owner and I'm analyzing and wanting to do it myself...There isn't much room in between the catalytic converter and the valves. What's the story ? Should it be removed
Thanks!
Old 09-03-2015, 07:07 PM
Weekend Mechanic
vulcan300's Avatar
I didn't remove any of the exhaust when doing the job. But, it would have been easier with it out of the way. The choice is yours. Pulling the cat may ultimately make the job a lot more time consuming if you have to deal with rusty fasteners.
86 911 Carrera Targa
Old 09-03-2015, 07:23 PM
You just lay on your back, feet to the passenger side and use the short feeler gauge holder. Not too hard.
206 637 4071
Old 09-03-2015, 07:31 PM
Perpetual Reassembler
2jmotorsports's Avatar
Leave it on. I just did this without touching the cat and I am a newb. Took longer to clean my greasy lower valve covers.
Old 09-03-2015, 08:38 PM
vash's Avatar
Leave it on.
Sent via Jedi mind trick.
poof! gone
Old 09-03-2015, 08:41 PM
Beautiful i'll leave the cat on and work around it.... One more thing how about the AC compressor, do you guys work aroumd that . How do you address the AC compressor.
Thanks, info is greatly appreciated.
Old 09-04-2015, 05:11 AM
Unbolt the compressor from the mount, leaving the hoses attached. Then you could lay it over the rear fender. Use a blanket of course, LOL.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 09-04-2015, 05:14 AM
vash's Avatar
Very true. This.
Of course the valves are easy when the motor is out. The easiest. Good luck.
poof! gone
Old 09-04-2015, 05:28 PM
