porscheboy1
Making an emergency front hood release
If the pull knob in the cabin and it does not release the hood it is a PITA to get the hood open. You have to remove the front bumper, locate and drill a hole in the bulkhead behind the bumper, fabricate a hook on the end of a heavy gage wire and insert the wire into the drilled hole and try to open the latch by moving and twisting the wire. I developed an easier method, installed it on my 78SC and it works.
Reference the pictures below. I fabricated a small aluminum plate with two holes in it and attached it to the movable hood release latch using the latch holding screw. I then took a 2-20 mild steel rod with a threaded end and attached a threaded steel clevis to it, attached the clevis to the other hole on the aluminum plate while running the other end if the steel rod into the right fender well through one of the grommets that route the electrical wires to the lights. I bent a hook on the end of the rod inside of the fender well. You could also make a 360 degree bend in the rod and tie a length of 80lb fishing line to it. If you need to open the hood with the emergency release just remove the left front wheel and remove the windshield washer fluid tank. You can then pull the rod to release the latch. This is a lot easier than removing the bumper.
The threaded rod and clevis comes from my stash of stuff for building radio control model airplanes. You can get it at Tower Hobbies.
Regards,
John
Life is good.
1965 356 SC
1978 911SC
1982 911SC
Old 09-04-2015, 01:45 PM
@ 3 digits
rayporsche's Avatar
Cool !!!! thanks for sharing...
'Enjoy the little things in life, for one day you will look back and realize they were the big things'
Old 09-04-2015, 01:50 PM
Slippery Slope Victim
NY65912's Avatar
You sir are a very wise man!
Mike²
1985 M491
Old 09-04-2015, 02:22 PM
Undocumented User
McLaren-TAG's Avatar
The ounce of prevention indeed.
Old 09-04-2015, 03:28 PM
Senior Member
Good job! I often think about mine breaking after 35 years of use, time to do something similar.
Old 09-04-2015, 03:45 PM
pors1968's Avatar
If you break the cable the Hood will pop up.Same for deck lid.
Old 09-04-2015, 06:21 PM
Also carry a piece of heavy string trimmer line to open the gas filler door.
Old 09-04-2015, 08:03 PM
porscheboy1
Talking Hood popping open when cable breaks.
Reference the Porsche workshop manual Volume VI, section 8, page 3.1-1/2. It gives instructions on how to open the lid lock when the control cable breaks. It is as I described in my post. There is some confusion here. Maybe some years of 911s have the lids pop open when the cable breaks and some don't. Anyone know?
Old 09-05-2015, 07:27 AM
Banned but not out, yet..
RSBob's Avatar
Did something similar for the rear trunk of the 914 which has an electric release. I have had to use it twice and it was a real life-saver. Your idea is excellent.
Old 09-05-2015, 09:04 AM
cycling has-been
bkreigsr's Avatar
hood - False,
deck lid - False
Old 09-05-2015, 11:32 AM
pors1968's Avatar
Originally Posted by bkreigsr View Post
hood - False, TRUE for 65-73 false 74and up
deck lid - False
MY bad if you have 74and up that a good set up for hood
deck lid true wont lock if no cable tension 65-89 they have a spring for safety
Old 09-05-2015, 04:08 PM
cycling has-been
bkreigsr's Avatar
The spring will not pop the lids up unless the catch mechanism is released - all lids, all years. The catch can only be released by the cable. Cut your cable off at the handle and see if your lid pops up. Also holds true for the gas fill lid.
Old 09-05-2015, 09:42 PM
On my old 2 litre car (long gone) both hood and engine lid had self-releasing catches if the cable broke. I thought it ingenious. My present car (78 SC) only the lid releases on cable break. I recently changed the cable and it is necessary to pre-tension the cable to get the correct adjustment. You don't have to cut the cable to prove this: just lift the lid, disconnect the cable and the lid won't now latch. But be careful if you don't get the adjustment right then you the can't release the lid. I removed the grille while I did this job.
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 09-06-2015, 01:23 AM
pors1968's Avatar
That true for 65-73 Hood and rear lid 65-89 And i dont have to cut my cable i did check mechanism all year i have about 20 in box.
Old 09-06-2015, 05:59 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Nice Work! Easily reversible
'85 Carrera Targa
PCA/POC
Old 09-06-2015, 09:58 AM
