irl irl is offline
irl's Avatar
Send a message via AIM to irl
how where are u installing aftermark belts
Lookint at putting in some racing belts, i don't really want to drill eye hooks into the floor, what are the options for the lap belts??
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 09-16-2015, 09:04 AM
Typically aftermarket seat belts are illegal to use on the open road in most states. I would check before you go that route.
Scott
1979 930 - Black on Black and in the woods
"My third child that will cost more in the long run" :shock:
Old 09-16-2015, 12:17 PM
Not sure on legality, but go to any cars and coffe typ meet up etc.... And you will see plenty of cars with harnesses of all configurations.
I have contemplated it myself, but unsure of the ramifications. Seems like it's done a lot.
1982 911 Targa, 3.0L ROW with Webers
Old 09-16-2015, 12:25 PM
I used rennline harness mounts for my takata 4-point harnesses. you can run both the stock belts, and race harnesses that way.
Harness mounting brackets - These brackets have been specially designed to allow you to install both, factory seat belts and aftermarket harnesses at the same time. Intended for the use of quick disconnect lap belts on both sides of the seat. This is a perfect set up for your street/track car. All brackets are designed to attach to the factory seat belt mounting locations so no drilling is required.
Rennline Harness Mount - Tunnel Side - Long - Porsche-Rennline, Inc.
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end.
http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html
Old 09-16-2015, 12:27 PM
irl irl is offline
irl's Avatar
perfect just what i was looking for. Going with a set of backdate look sabelts or repa remakes.
79 SC unmolested
25 GTS
Old 09-16-2015, 12:29 PM
shipfaced's Avatar
I replaced stock-belt mounting bolts with forged eye-bolts and used a "snap-in" solution. Easy to install/remove and does not interfere with stock belts. Shoulder belts mount to rear seat lap belt mounts and you MUST use a harness bar. All parts (eye-bolts, belt snaps) are available from belt suppliers.
Old 09-16-2015, 12:46 PM
yes, good point and very important. I have a bolt in roll bar, the shoulder belts attach to it.
Old 09-16-2015, 12:49 PM
irl irl is offline
irl's Avatar
Well after reading a bit, to complicate things I have a set of classic ST seats that obviously don't have belt mount locations so I guess Ill have to get what looks like side mount panels or eye hook bars. To be really safe, do most just go through the floor with these aftermarket belts??? Cool on a heavy track car but pretty rough looking.
79 SC unmolested
25 GTS
Old 09-16-2015, 01:06 PM
Look for a copy of the install instructions for Schroth belts. That will tell you a lot about belt installation and proper geometry. They also make the only sensible 4 point option for the street, assuming you have appropriate seats.
JR
Old 09-16-2015, 01:08 PM
shipfaced's Avatar
To the OP, not sure I am following you....I can't imagine mounting belts to ANY seats, always the floorboard (or factory mount points). Cruise the belt manufacturer sites (there are several) for solutions available. I chose the snap-in solution so I can have harness for DE/Auto-X but not have to deal with them rattling and clanking for street use. Takes 5-10 minutes to remove them and go back to stock.
Old 09-16-2015, 01:16 PM
irl irl is offline
irl's Avatar
Sorry at work, not looking in the car. trying to research sitting at my work desk. sounds like stock belt mounting points are on the body. Ill review the above options once i get a better look tonight and know what Im talking about.
79 SC unmolested
25 GTS
Old 09-16-2015, 01:21 PM
Read this first:
SCHROTH RACING > Professional Racing Harnesses
Then read the links here:
Harness Information » HMS Motorsport
Old 09-16-2015, 02:37 PM
