Your first problem sounds like a lean mixture or IAC problem.
Having it just die with no spark sounds like a DME problem. Does the tach bounce when you crank it? Do a search on DME trouble shooting steps or page Ingo.
What brand DME relay did you install? It didn't have the initials URO emblazoned on it did it?
Rick
88 Cab
Old 07-30-2016, 08:38 PM
steely's Avatar
+1 on the URO relay - not a good rep
Have a quick look at your speed & reference sensor cables - if the insulation is crumbly, that's not a good sign.
Do you have a bentley workshop manual? Troubleshooting chart is a good place to start.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 07-30-2016, 08:52 PM
Put a bottle of dry gas in the tank... you may be battling an accumulation of water rolling around in the bottom of that tank. Sounds like you have a spark related issue, but the early post suggests you may have some involvement with fuel as well. Has the filter ever been changed out?
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 07-31-2016, 05:54 AM
