Temperature gauge not working
H,
I have a 84 3.2 and the temperature gauge does not seem to be working. Can someone tell me where the sensor is and a part number please? |
Brew Master
I think the temp sensor is up in the "triangle". Either there or below and to the left of the oil pressure sending unit. I'll take a pic of both locations while my engine is out.
Nick Last edited by cabmandone; 04-23-2021 at 12:46 PM.. |
Thank you
Brew Master
I think the sensor below the large round pressure sending unit is the one you're looking for. Both are to the right of the engine fan. If you have air conditioning, it will be below the compressor. I think the one in the triangle (top right and front of the engine) is for something else like an idiot light but I'm not 100% sure.
Nick Last edited by cabmandone; 04-23-2021 at 01:28 PM.. |
Brew Master
Someone needs to ask Pelican why in the hell I had to do a google search for "911 oil temp sending unit" and found it from a competitor and then did a part number search to get a result from Pelican. I was literally on their parts site and did a search for oil temperature sending unit and got no results.
https://www.pelicanparts.com/More_Info/91160611200.htm?pn=911-606-112-00-M100
Nick |
Now I am confused, I have been given 2 different part numbers.
911-606-112-00 930-606-118-00 Which one actually goes to the dash temperature gauge? Last edited by chateau; 04-24-2021 at 02:09 AM.. |
Brew Master
Under Product info for the one I linked:
Oil Temperature Sensor (for Oil Temperature Gauge)
Nick |
Thanks!
When in doubt about a part, just call them and talk to a human. They can make sure you get the right part.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
RETIRED
The Pelican staff often have to do a Google to find stuff. Inside secret, don't tell anyone.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
RETIRED
I addition. Did the sender work then quit or did it not ever work? If it did, look for the part #. You may have to pull it or turn it a bit loose. Replace same for same.
Check continuity with the wiring to the gauge to see if it is not a wiring issue.
