Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
How to remove the heater controls from an early 911?
Hi all. I'm in the process of changing the vinyl on my dash face, and I need to remove the heater controls to do it. I can't seem to figure out what the next step is after I remove the 8mm nut holding it to the chassis. Do the heater lines easily disconnect, or is this one of those projects that looks easier than it actually is?
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 09-21-2015, 12:54 AM
Elombard's Avatar
I cant remember the details but its more difficult than it looks. There is some hidden mount points or something that make it tricky. Getting back in place is even worse. I think I remember its a lot easier with the radio out if you have not already removed.....for weight savings :-)
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 09-21-2015, 04:04 AM
Shaun @ Tru6's Avatar
Remove steering wheel
Remove clamshell
Remove knee pad and ash tray
Remove fiberboard cover over fan in trunk
Loosen 7mm nuts locking the cables to the HVAC directional vents, pull cables out
Remove passenger side vent and associated tubing
Remove 10mm nut holding the HVAC control levers to the body
Remove HVAC wiring to body and lights to it
Pull/push control levers through multi-hole grommet, can just remove entire grommet from body
Pull control lever unit out
Tru6 Restoration & Design
Old 09-21-2015, 04:27 AM
A most annoying job. If you're patient, the faceplate can be pulled out enough to work the vinyl around and under it. Just have to remove the one bolt for that.
206 637 4071
Old 09-21-2015, 04:59 AM
Rennch on YouTube
rennch's Avatar
Duh...of COURSE that's the solution. for that one I'll just do it in place. Thanks all.
Michael O'Neal -
Old 09-21-2015, 07:24 AM
rokemester's Avatar
What's required to change the vent control lights. How many are there? Need to pull out the Bentley.
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 03-19-2016, 05:25 PM
