| SCaircooled Join Date: May 2014 Location: Evansville, Indiana
				911.126.124.01 Air Conditioning Bracket
			Exactly where does this go in relation to my York AC unit?    | ||
|  12-11-2014, 09:22 AM |
| It's a trap... |
			I can post a pic later tonight after work if you don't get a response by then.
				__________________ Run like the wind, straining the limits of machine and man.... 2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys). | ||
|  12-11-2014, 10:22 AM |
| Registered Join Date: Dec 1999 Location: Richmond, VA  USA
			It mounts on the left top corner of the A/C mount.  Note the diagonal A/C support in the lower left of the photo.   | ||
|  12-11-2014, 12:55 PM |
| Registered |
			You can run the AC compressor mount without it, the base plate weldment that attaches to the shark fin shape support is plenty enough.  Here is an example of a complete Kuehl 911 507 Kwick Bracket system on a 73T with webbers: Shark Fin Bracket  Triangular Head Support Bracket  Base Plate Weldment Bracket  Kuehl Slider Plate  Kuehl 507 Adapter with Kuehl 507 Compressor   | ||
|  12-11-2014, 04:15 PM |
| Registered |
			Sweet setup Kuehl, that may be just what I need to get the A/C functioning on my '84 with Webers. The aluminum factory bracket won't clear the heater duct and the compressor won't clear the passenger side carb.
				__________________ '84 Carrera Targa (3.0 with SSIs, Webers, DC-19 Cams, MSD) - Sold | ||
|  12-12-2014, 05:03 PM |
| Tired Member | Quote:
 I'm rebuilding the car, including a heater back date, and would like to replace the "mountzilla" and utilize what came with the kit from your company. But that only included the slider plate and adapter. I need the Shark Fin Bracket, Head Support Bracket and Weldment Bracket. Do you sell those individually?
				__________________ Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec | ||
|  02-17-2015, 08:30 AM |
| Registered |
Soon, we will offer the Shark Fin, Head Support and Weldment base plate as a 'set'.
				__________________ Kuehl 1987 911 cab, modified https://griffiths.com/ | ||
|  09-24-2015, 04:23 AM |
| Tags |
| air conditioning |
