Cat bypass pipe vs gutted cat
A PO of my '82 apparently gutted tha catylitic converter. I'm guessing that functionally this has the same effect as using a bypass pipe. I'm fine with that because there's no smog testing sheer I live. But is the sound any different?
Old 05-13-2016, 05:53 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Yes, the exhaust will be a bit louder not much but compared to a stock car
'85 Carrera Targa
PCA/POC
Old 05-13-2016, 05:59 PM
Yes, but do you think there's s difference between using a gutted cat and a straight bypass pipe?
Old 05-13-2016, 06:08 PM
Cars Ruined My Life
impactbumper's Avatar
six of one half a dozen of other
Old 05-13-2016, 06:12 PM
DRACO A5OG's Avatar
What I noticed is the straight pipe is more raspy. My MK Euro Muff had a bit more bass.
I now have the OEM Euro Muffler, it is definitely quieter than the MK but I also have cut out air box cover so I have intake noise too.
'85 Carrera Targa
PCA/POC
Old 05-13-2016, 10:05 PM
Mony's Avatar
Just removed my cat and I welded in my own straight through pipe. To be honest, for the average person, there isn't really any sound difference. If you focus a bit, you can notice it's a tad bit louder at the high rev range. otherwise just remove the cat, you want your engine to breathe.
A Targa.
Old 05-14-2016, 11:35 AM
Ramp's Avatar
In a different car, I gutted the cat's rather than replace as there were 4 cats and 2 weren't needed. I didn't like the sound so I ended up replacing them.
Point being, the sound will vary between a gutted cat and other pipe options. gutted cat on a 911 may be just fine.
'86.5 Porsche 928S
'87 Porsche 3.2 Cab
'12 Jaguar XJ
'14 Mercedes GL550
'16 Mercedes C300
Old 05-14-2016, 02:08 PM
Senior Member
Jdub's Avatar
I'd always advise removing the cat. and running the straight pipe. You will never remove all of the honeycombing as I understand it and a straight pipe is a cheap and simple solution. Now you don't have this option obviously but an SC cat in good nick is worth something up until all our cars are sunsetted from testing.
'78 Targa in Minerva Blue
Old 05-14-2016, 02:19 PM
