Caveman Hammer Mechanic
ClickClickBoom's Avatar
3.2 engine oil thermostat?
Ok,
Rummaging around in the manual, could not determine the level of disassembly necessary to replace the engine mounted thermostat.
Opine!
eric
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 11-29-2012, 07:17 PM
ASE Master Tech - 35 yrs
larrym's Avatar
as i recollect - remove 2 6mm nuts and pull it out
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 11-29-2012, 07:20 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Engine oil thermostat.
larrym is spot on:
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-29-2012, 07:23 PM
Thanks guys!
I was wondering how much intake stuff removal is necessary? My car never gets up to 180F/80C, the manual says that the thermostat is set to open at the above temp.
I was thrashing about the shop, measuring the dogs butt temp and decided to backdate the gauge system. I removed the temp gauge from the '75, and the oil pressure gauge too. Swapped the senders from engine to engine and now I have numbers to refer too when I look at the gauge. Found an intake tube nut loose, tightened that sucker down and the idle hunting is officially gone.
Good stuff!
eric
Old 11-29-2012, 07:36 PM
Thermostat test........
Eric,
If you decide to pull and test the engine thermostat, you might as well test the auxiliary thermostat too. A simple water bath test could determine the operation of these thermostats. If I remember correctly the engine thermostat operates @ 176°F(??). While auxiliary thermostat operates @ 186°F.
For peace of mind, I like to see these thermostats open & close during tests and install them knowing they work.
Tony
Old 11-29-2012, 08:00 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1
'85 Carrera Targa
PCA/POC
Old 11-29-2012, 09:16 PM
ganun's Avatar
Reviving this older thread to ask the question: Does the thermostat have a preferred orientation given that the two openings are at different levels?
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 10-07-2015, 06:08 AM
Yes, the mounting holes are offset so you can't put it in the wrong way though.
Old 10-07-2015, 06:57 AM
