Difference between 1980 CIS & 1981 CIS
Anyone know the difference between 1980 and 1981 CIS ? I have a 1981 CIS and want to put it on my 1980sc.
Old 10-06-2015, 08:14 AM
Steve F's Avatar
I thing I think is the 1981 had steel injector lines, which probably makes no difference.
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 10-06-2015, 08:27 AM
ROW '78 911 Targa
timmy2's Avatar
There may be some Lambda controller wiring differences. I don't have access to my schematics until tonight. But if you have factory manuals they show the wiring.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 10-06-2015, 08:30 AM
pors1968's Avatar
No difference.
Old 10-06-2015, 08:31 AM
CIS unit.......
If you are putting the complete '81 CIS unit, then it is just an installation process. There are some differences between '80 and '81-'83 CIS components like WUR, FD, ECU, and fuel lines. You could mixed match the components and still have a good running CIS if you know what you are doing. Also be aware of the differences between USA and RoW models. They are similar until the introduction of the lambda system in '80. Why are you replacing the '80 CIS? Are you having some sort of problem? What happens after installing the '81 CIS and you still have problem/s? Keep us posted.
Tony
Old 10-06-2015, 08:41 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
As Tony said, many components are different. Look here to see which ones.
911 CIS Primer - Cross Reference
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio
Old 10-06-2015, 10:13 AM
I bought the car with motor and tranny out and th PO said there was problems with the 1980 CIS. It came with another CIS from 1981 which he never installed, it's in better shape so I figured I would use it.
Old 10-06-2015, 12:05 PM
I see the 81 has an additional temp,throttle and enrichment switch compared to the 1980 CIS.
Old 10-06-2015, 12:25 PM
Still here
pmax's Avatar
The control unit is different. Do you have the 81 unit ?
Old 10-06-2015, 12:31 PM
The CIS primer says plastic fuel lines where used up through 79. Supposedly the CIS that came with the car is a 1980 but it has plastic lines? The 81 has metal lines and several differences including the control box. I think I might be ready for carbs!
Old 10-06-2015, 12:45 PM
Still here
pmax's Avatar
80 has plastic lines.
Tony's the expert in these systems. What's wrong with your current setup ?
Old 10-06-2015, 12:50 PM
Ok thanks
Old 10-06-2015, 01:29 PM
I don't have a set up right now CIS was off motor when I purchased the car po said it had problems and no one could fix it so car was parked. Motor is out getting rebuilt soon and just trying to sort out my options for fuel delivery.
Old 10-06-2015, 01:31 PM
From what I have read I guess I will have to stick with the 1980's one and try to sort things out and use the 81 for its parts.
Old 10-06-2015, 01:33 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Hold on there for a little second. Just chew on it for a while.
There are a handful of additional controls the 81 box has that the 80 does not. Most importantly, a WOT switch that you should be able to take advantage of.
Listen to pmax and consider Tony (and timmy2) as your new best friend.
Alternatively, go to carbs, get a few more ponies and drop you mileage 10mpg. Don't mind the myriad carb hassles and their cost.
1981 911SC Targa
Old 10-06-2015, 01:50 PM
You can install the 81, using the lambda harness on the engine from the 80 so you match at the connector and the lambda system. The 80 has a 6 pin connector coming off the engine to match the chassis harness. The 81to 83 has a 12 pin connector off the engine.
Bruce
Old 10-06-2015, 02:01 PM
Now I'm a little confused according to the CIS primer the CIS shown in my pic is a 1981 due to the 2nd throttle switch however it has a 6 pin connector as shown. Bare with me guys I'm new to CIS.
Old 10-06-2015, 03:43 PM
Here's a few more pics maybe I'm wrong but it appears to be a 1981 CIS.
Old 10-06-2015, 03:50 PM
My mistake I guess I must have transferred the wiring off the 80 over to the 81 last year.
Old 10-06-2015, 04:13 PM
Pictures in posts #17 and #18.........
DP,
Are those pictures of your spare CIS unit or the one installed in your motor? The engine wire harness in the picture is from an '80 CIS with 6-pin. Could you post a picture of the chain housing cover for cylinders 4-5-6 of your motor? Other identifying features would be (for your motor):
a). What is the Bosch ID numbers on the ECU?
b). What is the Bosch ID numbers on the WUR?
c). What is the serial number on your engine block?
If you could provide these information, we might be able to decipher the true identity of your motor unless PO installed assorted CIS components in your engine. So let's take it one step at a time.
Tony
Old 10-06-2015, 04:29 PM
