Clay,
What is the black box with tubes coming from each throttle body and what does it do? Your engine is super clean looking. Thanks
Rutager West 1977 911S Targa Chocolate Brown |
Thanks.
It's a vacuum manifold. It collects vacuum from each cylinder to provide a clean even vacuum signal for the MAP sensor. |
This is awesome. So no need to drill into the back of the camshaft for cam position?
Question:
Tell me about crank sensor integration; which is the most critical of all the sensors in an ECU application. Is a front pulley mounted timing wheel needed with high duration/lift cams to reduce the signal noise??? or are they all used for ease of access to crank sensor???
1980 911 - Metzger 3.6L 2016 Cayman S |
Hello all, Andrew are you still working with AEM? Your website shows MoTEC these days but not sure how current that is. I found the thread looking for more information on the AEM distributor adapter setup, is that still available?
Wondering about a 930 use case for this setup and if you've spent time on boost control. Thanks!
1990 928 GT, gone but not forgotten 1981 930, der Go Kart |
