Location: behind the redwood curtain, (humboldt county) california
Is it possible to drill new holes in the bar to make it adjustable??
I have purchased an 85+ rear 18 mm bar and Chucks well made adjustable drop links for my 74 coupe.
Looking at the bar, it looks like there is sufficient material to be able to drill another hole or two to make the bar adjustable.
Is this workable?? or am i going to see the bar fail?? I could deburr and peen the holes.
chris
Would Lengthening the drop link reduce the angular misalignment significantly??
Old 10-19-2015, 09:28 AM
tobluforu's Avatar
As long as the adjustable drop links can reach, I don't see why not? I take it you are looking for it to be stiffer, you might want to put it on first and test. By the way, I did this on another car years ago.
Old 10-19-2015, 09:32 AM
Thanks tobluforu,
I am going through the front now, but am looking down the road to do the rear. I currently have a 18 mm rear and 20 mm front Carrera bars
I am going up one notch from 18.8 t bar to a 21 mm. The rear could be a 27 mm t bar with a bit of adjustability to help balance the handling.
Does this sound doable??
chris
Old 10-19-2015, 09:57 AM
rfloz's Avatar
Yes. Mine has 6 years of A/X, a few track days and plenty of So Cal canyon miles - no problem.
Bob F.
1984 Carrera Factory Turbo-Look
Old 10-19-2015, 01:49 PM
Send a message via Skype™ to Porboynz
Be prepared for some hardened steel and blunt drills.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 10-19-2015, 11:25 PM
