max wheel/tires on early cars?
I currently have 16s 6's and 7's but with 205 tires front and rear installed by P/O.
I would like to have more rubber at rear. I believe P/O have problems with rubbing at rear and 'may' have had 225's there?. Rear does not appear to have excessive camber yet although is lowered. I am battling with the idea of RS or Carrera flares (whats the difference?) Or attempting more neg camber. Or changing to 15" wheels? Anyone any combos which work other than stock of course! advice appreciated, And merry xmas all -Benhttp://www.pelicanparts.com/pmpre/images/twin_plugged_targa/close_up.jpg
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001 1984 Carrera 3.2 IROC RSR look Last edited by twin plugged targa; 12-24-2002 at 07:09 AM.. |
Ben-
You may or may not be able to fit 225/50s in the rear without rubbing. I have seen a lot of variation in the early cars as far as clearances go, and the difference between tire manufacturers within the same listed size is another variable. Most people have not been able to do it with 16" wheels without some clearance problem. I was able to fit 225/50-15" on 7" rims on my lowered '73 without a problem (w/ 26mm rear T-bars, 18mm rear sway bar, 1-1/2 degrees negative camber, and rolled fender lips), but I have had friends with the same year car who rubbed on one side with the same tire/wheel combo. With a custom offset rim, it would be a piece of cake. Or with larger flares, as you are obviously thinking. RS, SC and Carrera flares are all the same width, they just differ in the shape of the wheel arch bead.
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 Last edited by ttweed; 12-24-2002 at 09:28 AM.. |
I vote for leaving the bodywork stock, the paint looks beautiful, and if you get creative you can get 225's under there and keep the stock look.
I didn't think you could get 225/50's in the back until I saw this thread...the 1970 911T conversion 90% done If you decide to go this route, be careful in your testing. I've seen two nice early cars with the paint burnt about 2 inches up from the lip because the tire rubbed. It seems the lips aren't the real problem, whereas in the front the lips are the only issue. Another option is to find a pair of 7" 944 turbo fuchs that went on the front of that car. They look just like 911 6's, they don't have the same "dish" look because they put the extra width on the inside. These should allow 225's to fit easier, and you may even be able to squeeze the 944 8" fuchs from the back of that car. They'll look just like your 7's on the outside and put an extra inch of width on the inside. These are considered rare, the 944 only used them for one year but they do come up. Part numbers for both are in the Bruce Anderson book. Last edited by Todd Simpson; 12-24-2002 at 10:35 AM.. |
I do remember that thread now,
I may increase the camber 1st and then have a go. Bit nerveous about having the fenders rolled as p/o did it and damaged the paint!. That was not before he rubbed and bubbled the new paint AHG!I guess the brands of tires which are best are the old style tires without that rim saver extra bit of rubber? thanks for the comeback Ben
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001 1984 Carrera 3.2 IROC RSR look |
On a 1969
I currently have 15x6 - 205/50s on the front and 15x7 with 225/50s on the rear. Currently running 1 degree of negative camber (adding more soon) and lowered about 1.5 inches. Lots of room on the front - very tight fit when I tried 1 inch spacers. Tighter fit on the rear (closest fit on the passenger side).
Joe Riley 84 Carrera Targa 69 911S Coupe Click here for 911S project "updating as I go" |
Does anyone know if 15's 7" with 225 tires are wider than 16's 7" with 225 tires?
know it may sound daft but here goes! also are there any known tire manufactureres that work- have a better profile to reduce rubbing? -Ben just trying to figure it out before spending odles on tires
go to www.tirerack.com and type you tire size in. choose a tire manufacturer and look at the specs. they give all of the tire sizes and widths on that page. you should be able to figure out what your after. a 225 on a 6" wheel reguardless of 15 or 16 has the same width as long as the profile is the same.
'94 CMC Firebird Trans Am '86 951 LS1 (C-2) Gone ![]() ![]() '77 911 3.2 (C-1) Gone but not forgotten. http://www.pelicanparts.com/MotorCity/marcesq1 http://www.youtube.com/user/958Fan#p/u |
Marc-You are correct on the 7" fuchs from the front of the 944 turbo, they are the same offset as the 911 7" fuchs, the difference is they have more clearance for bigger brakes.
I gotta disagree with you about the 8's though. If addictionms can put 7's with 225's on the back of his car, and the 8's stick out the same amount, why wouldn't they fit? If anything, they would fit better, as the additional width would pull the shoulder of the tire in a little bit giving more clearance. None of this is firsthand knowledge, at this point I'm just asking why it wouldn't work. I'm still amazed someone got 225's on 7's on the back of an early car. Just looking at Ben's car you can see how close he already is with the 7"s and 205's. He'd have to do a lot of work or camber to get 225's in there.
Todd Doing business with leebparts? http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/555068-attn-leebparts-please-contact-me.html |
The 911 8" x 16" Fuchs with the 10.6mm offset "stick out" even more. All the added width is on the outside with that rim. TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 Last edited by ttweed; 12-27-2002 at 08:27 AM.. |
![]() My experiance with the 944 8x16s on the rear is actual.
'94 CMC Firebird Trans Am '86 951 LS1 (C-2) Gone ![]() ![]() '77 911 3.2 (C-1) Gone but not forgotten. http://www.pelicanparts.com/MotorCity/marcesq1 http://www.youtube.com/user/958Fan#p/u Last edited by marcesq; 12-27-2002 at 03:16 PM.. |
OK...I'm going to bow out from any more advice here, as I need to be learning, not consulting.
Tom-I understand your point about offset, the 951 8's would have the additional width half on the inside and half on the outside when compared to a 911 offset 7". I'll stew on the 911 8" fuchs rubbing on the inside of the front as opposed to the outside, that still doesn't make sense to me. The offset represents the distance from the center line to the mounting point? Is it a positive number or a negative number? Most other modern cars have 30-40 mm of offset, so the wheels sits towards the inside, correct? Thanks for the help, sorry for cluttering the board with bad info. Gotta make this one an FAQ. |
Turns out my prior experience with lesser vehicles does not always apply to our rolling obsessions. Regards. Marc |
Bandwidth AbUser
twin plugged, I have 6 & 7x15's with 195/65 and 215/60 Yoko A-008P's on a 73E. I have some rubbing on the right rear when cornering, but only when there's two people in the car.
Jim R. |
Jim, can you show us a pic of your car? Thanks!!!
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/ 1970 911S, 10 sec 67 Beetle (300 rear wheel HP) RGruppe#252 |
Bandwidth AbUser
Here 'ya go...
Jim R. |
Wow, that is a nice car you bought! If you ever get a chance to shoot a pic in the bright light I would love to see a profile shot just to see how well that tire fits in the rear. Thanks!! Looks cool tho
All the offsets on Fuchs are positive (curbside of centerline), and the 911 8x16 ET10.6 Fuchs put the extra width on the OUTSIDE compared to the 7", not the inside! I have edited my post above to reflect that. The 8" 911 offset wheel on the front of a narrow body makes the track too wide and the tire hits the fender lip. The best graphic representation of the various Fuchs offsets was posted on another thread and I saved the image to my website because it was so helpful in visualizing the differences: Sorry for the confusion, TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
