Hello Pelicans, I have a G 50 AWD tranny from a 89-90 964 C4 car, I want to install in my 86 along with a 3.6L engine ,the question is : how easy is to remove the 4WD cone if possible at all and what is there available for blocking OFF the front end of the tranny ?
Thanks for all who want to chime in ! |
The 964 G64s are a totally different and unique animal which have a concentric shaft output arrangement that is going to be extremely expensive to by pass. If you have a g50 or 993 g64 then the t/p is still going to be a bear as the, t-bar and tunnel structure will have to be extensively modified to accept the much bigger g50 trans. Not something to be approached w/ a light attitude or wallet.
gearhead
As Bill has stated this is really a no go. That gearbox is like no other gearbox in the g50 family and would be extremely difficult and expensive to make 2wd.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
