Racer
Frank,
According the folks at Jerry Woods Enterprises, the spring plate mount gives you a more linear and more appropriate motion ratio as the suspension moves. In other words, mounting to the spring plate is better than mounting to the trailing arm.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
non-whiner
The sway bar mounts to the spring plate by replacing the eccentric adjuster with an eccentric bolt as shown in this diagram:
http://elephantracing.com/documents/911%20Rear%20Swaybar.pdf
"Too much is just enough." |
Max Sluiter
I've got some new Tarett 22mm RSR style bars available in case it helps you. The rear is an early bolt spacing. Bought them but decided not to use them.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
There was a bit of discussion a while back on the drop-link topic as well: Adjustable Rear Drop Link Attachment
'73 911T RoW (Project) '77 911S 2.7RS '76 914 2.0 Early911SReg #2945 |
Racer
I use Tarett sway bars on my race car. I have to use the trailing arm mount because of the raised spring plate front (chassis) mount on my car. The drop links would run into the frame rails if I used spring plate mounts. I had to get custom drop links from Tarett and mess around with spacers to get everything setup so the heim joints would not bind. I would have had no issues if I could have used the spring plate mounts.
Don't the aluminum trailing arms have a different shock angle than the 70 steel ones? I think they may require some machining there too. There are clearance issues at the top shock mount.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
You are correct RSTarga. Go to post #20 and it explains how to go about achieving the proper angle and clearance. There are a couple ways to do it and I plan on doing the one that requires removing 1".
PJ 78 911sc Targa 70 911T |
