Peter, our engine specs are near identical (if i remember correclty, our only difference was the muffler, and i may spring for a dansk sport to match), so i watched your build closely. I am also going for the maf, so we can trade notes. Did you ever get your car on a dynojet closer to sea level? I am hoping to benchmark you.
In a perfect world i may be doing some controversial comparisons next year that include dansk sport vs m+k, and sals maf/injectors/chip vs sw stage 2 chip/stock injectors/afm (paid for it, why not give it a try). On top of that, i would like to see if ssi's can produce more than 220rwhp, which I have been told by a well known source is the upper limit of what ssi's can flow... But which Sal seems to be surpassing. If sal can do that, he may just save me 2-3k $$$ on b&b headers... Although knowing me, if he can do that with ssi's, i may just go b&b anyway for even more power (given the great ssi resale value). Should be fun if I can find the time to do it all properly. |
I did take the car to a shop with a dynojet but the dyno's computer failed during the first run so it was aborted and I have not been back.
As per Sal's detailed instructions, I have removed or moved a few components to expose the fuel rails.
On the driver's side this is mostly disconnecting the three-plug sensor bracket, unbolting it and zip-tying it out of the way (label or mark the black connectors to put back properly). I also pulled the injector connectors. http://forums.pelicanparts.com/uploa...1448120152.jpg On the passenger side I simply removed the air filter/housing. I left the AFM in place. Also pulled the injector connectors. So far wiggling these off has been the most challenging. There's one on each side that's a little hard to grab, and the injectors themselves rotate a little making it hard to wiggle. Anyway the new injectors have a different connector, but an adapter is included for each. http://forums.pelicanparts.com/uploa...1448120359.jpg The above is about 30 minutes work for a novice like me. Next, I will open the fuel lines and pull the old injectors. Thanks for watching, Dave |
Well I'm ready to do the actual injector swap. Here's the Ford Racing injector that I'm installing, along with the adapter for our electrical connectors:
http://forums.pelicanparts.com/uploa...1448125937.jpg First I relieved the pressure in the fuel system by removing the pressure test cap. You will lose a few teaspoons of fuel here. More will be left in the rails and will spill when injectors are pulled. http://forums.pelicanparts.com/uploa...1448126086.jpg Next I pulled the injector retainer clips (not used on new ones) and separated each rail from its anchoring points. Then starting in the rear, I wiggled each injector out of the intake, then out of the rail. With a little lube provided I reversed the process, finally securing each rail as before. I rotated and verified full insertion of each injector before tightening the rails. I going to let the gas fumes dissipate a little then jumper the fuel pump to test for leaks. You can see the purple injectors on each side: http://forums.pelicanparts.com/uploa...1448126349.jpg http://forums.pelicanparts.com/uploa...1448126404.jpg Dave |
IT LIVES!!
I tested for fuel leaks, found none, then replaced the sensors bracket and connectors. I connected all the injector wiring. Then I went to my Sal-modified DME. Sal want his fuel quality switch set to #4. The switch serves a totally different function on his DME, and is used to fine-tune the fuel mixture. The blue knob at the left of the picture. http://forums.pelicanparts.com/uploa...1448128802.jpg Then I installed Sal's custom chip. You can see it to the top of the picture. http://forums.pelicanparts.com/uploa...1448128887.jpg These posts have been real time install, and even with breaks, pictures and inexperience the job took me about two hours. The car idles extremely smoothly, and throttle response is awesome. I only let the engine run for a minute or so. i want to work on my new MSDS air filter w/adapter. Then I will let engine come to operating temp and start to go through some of Sal's calibration steps. Mostly analyzing AFR's at various RPM's and loads. So far I am very pleased. Thanks, Dave |
Thanks for the pics Dave! Very helpful to a fellow novice considering the same.
Thanks. Car seems fine, but here's my weather situation. No fun for a while.
Dave http://forums.pelicanparts.com/uploa...1448134565.jpg |
Nice. Looks easy. Easer for me with a heat backdate and ac delete. We have no snow, but the salt is down.
How much calibration can you do in garage? Snow will be my reality for the next 4-5 months. |
I can get a very good idea of what the mixture adjustments may be from just the tests done parked in neutral.
If testing in a garage be sure you have ample air flow, you'd be amazed how quickly you can deplete air in a closed space and CO is not your friend! Use caution. |
Due to family visitors I have to put the 911 on its storage lift for a few weeks. There is plenty of ice and salt on the roads here so I don't think I will drive it now for a while. Before I put it away, I noticed a couple of things (all good).
I warmed up the engine. Very nice cold start and solid idle. I set the idle to 920 with jumper and digital timing light. I reved to 2500-3000 and held each speed constant. The AFR stayed in the 14.6--14.8 range My idle AFR was 14.8.15.0. I closed the mixture screw about 1/4-1/2 turn and got 14.5 @ 2500 and 14.6-14.8 @ idle. I jumpered the brown wires at DME, and just like Sal said it stayed at a 12.9-13.0 at 2500 and at idle. I unjumpered the brown wires and all went back to as before. On no-load tip in the AFR's go down to 13 or so, but we'll see more on the road in a couple of months. Happy Thanksgiving to all, Dave |
Dave,
I'm very pleased with these results, the system as is will most likely need no tune changes on the chip. Your AFM is very much on spec with my test AFM, I have a AFM with only 5000 miles on it! I had this AFM flowed on a flow bench and the chip is matched to this special test AFM. The fact that you hit the same targets tells me your AFM is in decent shape. The other important model is the Fuel Injector model and that I know is spot on since those are my matched injectors. Any deviations between the test setup I use here and your car would be the result of an AFM not matching mine or fuel pressure changes. So far so good. When you are ready to road test drive let me know. Enjoy. |
the brown wires are traditionally for retarding the timing for emissions if my memory serves. California emissions suck. Is it being used to richen the mixture as a "track tune" here? :-O
subscribed
It's not a track tune, it's a special calibration mode for all my chips. It makes it extremely easy to see if base mixture is correct across all operating conditions. This mode is only to be used for calibrating and verifying mixture.
The injectors look identical to the 24# Ford injectors offered here: Ford Racing Mustang EV6 High Flow Injectors - 24 lb M-9593-LU24A (87-14 All) - Free Shipping I wonder if the 36# Ford injectors are also the same color? Cheers, Joe |
Yeah Joe
That looks like the one. You need electrical adapters. They came in Ford Racing box. Dave |
Did the Ford racing box say 24# on the label or was it marked 36#? Just curious. Joe |
Dunno. Sal?
Those look correct. Definitely 24# injectors. Dave |
Just a warning, the injectors may be drop in... But without the chip being programmed for their unique specs, you will cause more harm than good (if they even run).
Cheers, Joe |
Cheers, Joe |
Sal's system would cost $600 more on top of the Ford injectors. I can understand the desire to save money. The AFM is indeed very adjustable, and with a good wide band O2 sensor or dyno you may eventually get an acceptable result. Sal has done this on the fuel and timing side with his chip and DME. Good luck with your efforts. Dave |
More than saving money, I still need to smog here in Cali. I think I could get away with the injectors but all the rest would be questionable on the visual. These smog techs here in Marin Co are pretty sharp on older 911s and I wouldn't want to push my luck. My paranoia tells me to avoid any potential problems for myself or future owner... Joe |
Do not attempt to put these 24# injectors in a stock system with a stock DME! Even though flow wise the are close to stock the injector characteristics are way different. These FORD injectors are top notch matched set of modern day 6 hole injectors but the inj offset times are very different as is the low and high slopes. I've totally re-written the fuel model in my chip to match these injectors perfectly.
I'm also very confident that if a car passes California smog with the stock setup it will pass with these injectors as well, most likely even better numbers simply from the much better low flow atomization. The reason I sell chips with injectors is simply because I have to have at least one thing rock solid, either I need the air model or the injector model solid. Or with my MAF both are solid. With my injectors + Chip working with the stock AFM I know I can trust the fuel model so any deviation in AFR I know is from the AFM out of calibration or Fuel pressure sightly off. But if I have a chip with old injectors, old AFM and unknown Fuel Pressure I just chase my tail trying to figure out what's causing the deviation. These 6 hole injectors can be sourced for a fraction of the cost of OEM ones and are far superior technology, this is why I mated them to my chip. Hope that helps. |
Joe,
You may achieve some level of tune by tweaking the AFM but you will never properly model the fuel doing that. It's not possible, the injectors are very diffrent than the stock ones, not just the flow rate, the bigger issue is the on and off ramp times and the low and high slopes. If you want to really understand this get 2 books from Greg Banish he covers these topics in great detail. Just to give you and idea of what I'm talking about see this video from Greg: https://www.youtube.com/watch?v=JZmV10pFsCM He clearly shows the dangers of not understanding how injectors actually work. Quote:
Here is a good primer.
https://eficalibrator.files.wordpress.com/2014/09/fuel-injector-article.pdf Long story short, even if you adjust your afm for ideal afr's with the new injectors, you could still be way off on your fuel delivery... And this down on power and efficiency. You would just be tuning around a problem. The above two books are great!!! Greg banish works as an oem engine tuner... And does work on aftermarket stuff because it is so easy and relaxing for him. To get the most out of a modern injector... You need a dme that will talk to them correctly. I also see the benefits of modern injectors... That is why my DME is out of my car to mail to Sal. No more 200-250$ an injector, for solid, but 30 year old tech. |
Great article, also written by Greg!
Bottom line, you can't just drop in any injector and expect it to work properly. Sure some may work, or you may think they are OK but if not properly modeled you get injection time deviations. Like they over fuel at low pulse widths (below 2ms) and under fuel at the higher PW (above 6ms), if this happens you just leaned out WOT conditions! And if the inverse happens you can easily over fuel at WOT. You will never get this correct by just adjusting the AFM. You could tune around issues like these by tuning fuel trim maps in the chip but that's also not the correct way to do this. What I did is re-write the entire injector model portion of the software using Greg's principles. My code even has low and high slope modeling ability, the stock 84-89 code does not. Back in the 80s they simply did not fully understand dynamic injector characteristics. Plus the OEM injectors are low-impeadance and are not that diffrent on the low and high slopes but most modern day hi-imp injectors are very different on low and high slopes, you must provide a way to model for this. Quote:
Not sure what you mean by "all the rest would be questionable on the visual". Good luck, Dave |
I'm not to sure the MAF would pass as the stock AFM. Might be a dead giveaway. I'm telling you these smog techs 'round here are pretty sharp. Joe |
Dave |
Joe |
Cheers, Joe |
I've been following this thread with great interest. I am very attracted by the idea of modern injectors and an updated and thoroughly checked out Motronic unit. My engine is apart right now, so I'm not sure going this route right at this time would be smart. I'm thinking I'll send my injectors out for a clean and inspection by Mr. Injector, put the engine back together and running so I have a baseline, and then go with Sal's system. Thoughts?
He is a pleasure to work with and so far there is a significant increase in smoothness and throttle response. No parking lot jerk, which maybe you did not suffer. It was a great experience to work with Sal, and pick up even a tiny amount of his knowledge. Good luck, Dave |
I always suggest starting with a stock setup as a baseline. I have a few simple tests I always have someone run before we touch anything. You can't expect a chip to fix mechanical issues or other engine issues. It's very wise to start with the stock setup especially on a fresh build. Few exceptions would be extensive mods like twin plugs, you could never run that on a stock chip anyway.
Joe,
The stock DME can run hi-imp injectors without any issue, what you have to do is build a chip that can properly model them and that's not easy. But the DME it self needs no changes to actually run the injectors. Rule of thumb with EFI systems is that a lo-imp designed system can run hi-imp injectors but not the other way around, you CAN NOT take a hi-imp EFI and put lo-imp injectors in it, you will cook the injection driver circuit! Quote:
Sal, I stumbled into this Jeep forum and am basically trying to duplicate what they are doing. Also, it seems the Jeep 4.0 injectors flow very close to Carrera injectors. 0280155703 injector swap, runs good! - JeepForum.com Injector upgrade thoughts. - AUSJEEPOFFROAD.COM - AJOR I already picked up a set of 2.4 4 cyl. Caravan injectors to try out but am waiting for EV6 adapters I ordered. Meanwhile, I'm looking into picking up a set of '96 Neon 2.0 injectors and these will not need the adapters. They have a flow of 238cc (22.6 lb) @ 43psi, Part# 0280155703 (OEM# 5277739) which is virtually identical to the Carrera injectors. So, off to Pick 'n Pull to see what I can come up with. They charge $7 per injector but this weekend is half price...can't wait. I'll let you know how it goes. Cheers, Joe |
Joe,
If they are hi-imp injectors they will not properly work without chip changes, even if the static flow rate is exactly the same they will not work because hi-imp injectors typically have 2 times the on time. Our lo-imp stock injectors have a inj offset time of about 0.3ms (the amount of time it takes for injector to open) but most hi-imp injectors are well above 0.7ms this is a huge difference at low flow rates of about 1.8ms (this is the overall pulse width at idle and low loads for our cars). You are risking some significant compromises using hi-imp injectors without properly modeling them in the software on the chip. It has taken me years to properly understand and code for things like this. I also attempted what you are trying to do, I finally had to re-write the code to get it correct. What will likely happen is that you may hit the target afr at lo loads but then be way rich at WOT or visa-verse. Without properly modeling the offsets and the lo and hi slopes you will never get fueling 100% correct. And making matters worse is that hi-imp injectors have a lot more deviation in lo and hi slopes. To just touch the surface of this topic see this video: https://www.youtube.com/watch?v=JZmV10pFsCM See the red line in that video, it illustrates just how different low and high slope can be in a hi-imp injector. Lo-imp injectors don't vary this much. Quote:
| All times are GMT -8. The time now is 06:38 PM. |
