Radio delete panel fitment issue
Bought this here on our host's site, it doesnt fit flush within the recessed area like I imagined it would when I purchased it. Also is loose and tends to shift downwards on one side when driving. Anyone make a panel that fit's the hole properly and is recessed instead of sitting atop the surround loosely?
Old 11-10-2015, 10:52 PM
esonefour's Avatar
I used a dremal and made it fit the inside edging, and drilled two holes in the tabs and cable tied it in from the back.
Old 11-11-2015, 12:21 AM
es is right....a little time with sandpaper on a flat surface, and slight radius on the corners, to get the panel to fit the opening.
For a tighter fit, I used heat on the tabs to bend them to be a little more aggressive in their grip of the dash cut-out.
pd
Old 11-11-2015, 03:23 AM
