Weber transition port sizes
On Weber 40 IDA/IDT etc., does anyone have any idea the factory dimensions of the fixed transition ports near the edge of each throttle plate? I suspect my recently acquired set has been drilled/enlarged as I'm unable to lean the mixture off idle > about 3800 rpm using different idle, main, air correction jets and float setting.
I can adjust the mixture before and after the above range (confirmed with A/F gauge).
Thanks,
Sherwood
Old 11-16-2015, 06:34 PM
1QuickS's Avatar
From bottom to top:
IDA, IDAP & IDS:
  • 0.80
  • 1.10
  • 1.35
IDT (not IDTP):
  • 1.00
  • 1.10
  • 1.35
IDTP:
  • 0.70
  • 1.30
  • 1.20
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 11-16-2015, 07:30 PM
Whoa. Thanks for the info Paul. Will try to confirm.
Much appreciated
Sherwood
Old 11-17-2015, 12:42 AM
