Studs on bottom front edge of front hood
There are two 6mm studs on the bottom front edge of the hood on my 74 911 which hold the upper portion of the hood release/latch in place. I have broken on of those studs off, and a small piece about 7 or 8 mm is still standing proud of where it was welded to the hood.
Have any of you had this problem, and if so, how did you fix it?
I don't always talk to liberal arts grads, but when I do, I tell them Big Mac and small fries!
1974 911 RUF Clone ('85 3.2; '86 915)
1974 914 ('87 3.2L & 915 transaxle)
2005 Boxster (Base car) Guards Red.
Old 11-12-2015, 07:24 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Oh my, that would be welding via body work sorry to write. Did you use some penetrating spray before removal or was it rust welded?
'85 Carrera Targa
PCA/POC
Old 11-12-2015, 08:08 AM
I would grind the broken stud flat then drill and tap into the broken stud. Use JBweld on the replacement stud threads. I did this on a floor stud for the wood pedal board, and it worked
well. Just go slow with your drill and get the new hole in the center of the broken stud with the correct angle.
Rob
Old 11-12-2015, 03:53 PM
Studs on bottom of front hood
Anyone had and solved this problem?
Old 11-15-2015, 06:26 AM
