rnln's Avatar
A/C question: the green o-rings size
I want to replace all the o-rings with green o-rings for R134A. The problem is that Pelican website doesn't say which o-ring for which hose. Does anyone know which o-ring size goes to which hose?
Thanks.
Fat butt 911, 1987
Old 11-12-2015, 01:10 AM
El Duderino
tirwin's Avatar
If you go to your local auto parts store you can buy an assortment of the o-rings for a couple of bucks.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 11-12-2015, 04:56 AM
This.
For 5 or 6 bucks you can get every o-ring you need and many you don't need.
Old 11-12-2015, 06:42 AM
rnln's Avatar
Thanks everyone.
As with PelicanPart, for future reference, here is what I just got form the rep...
Part #: 55-9807-901-M325
Description: A/C System Retrofit Kit - R12 to R134a Retrofit.
Brand: Santech Brand: X
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
Fat butt 911, 1987
Old 11-12-2015, 10:42 AM
kuehl's Avatar
R134a compatible o rings = HYDROGENATED NITRILE, aka HNBR or HSN.
Colors can be black, red, blue or green. In auto AC green is more common color.
For a 1984-1989, 911, stock system, from Pelican, you would order:
For hoses and components:
5 pcs of 999-707-247-40
3 pcs of 999-707-434-41
2 pcs of 999-707-251-40
For under compressor manifolds:
(4) 944-126-935-01
The only other o-rings you could replace would be compressor's
3 case o-rings, and the one in the nose seal, however for this you
would need a compressor seal kit. And, there is a small o-ring
where the expansion valves' external equalizer tube attaches
to the top evaporator outlet (which is usually not a problem child).
Porsche AC
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 11-12-2015, 12:41 PM
rnln's Avatar
Thanks kuehl
Fat butt 911, 1987
Old 11-15-2015, 12:58 AM
