Question Which caliper is this one?
Dear Friends
I´m rebuilding this 1976 911 coupe that i recently purchase, and I need help to try to figure out what type of calipers do I have, so i can buy the correct repair kit
I was looking at the Pelican and there is lot of options and models
1-) Caliper with Brake Disc Wobble Compensation
2-) Caliper without Brake Disc Wobble Compensation
3-) "M" Calipers
4-) "S" Calipers
5-) "A" Calipers
6-) With vented brake disc
Does any body knows what kind of system I have?
Ricardo
Old 11-16-2015, 02:44 PM
76 should be an M. Google PMB performance breaks.
They restored mine. Great company.
Troy
Old 11-16-2015, 03:29 PM
Bill Verburg's Avatar
Originally Posted by 1ricardo View Post
Dear Friends
3-) "M" Calipers
4-) "S" Calipers
5-) "A" Calipers
Ricardo
Front is A, rear is M
Bill Verburg
Old 11-16-2015, 03:33 PM
Charles Freeborn's Avatar
Front looks like an aluminum S to me. Rear appears to be the usual M.
Green shocks say Bilstein struts. Same set up as mine from the factory.
Even though the S is a more valuable part, the later SC A caliper stops better and is a direct bolt on with the S type strut mounts. I was able to trade my worn out S calipers for ready to go A's from PMB. If a magnet won't stick to it, it's probably an S.
Front Suspension re-build
Rear Suspension Re-build
-C
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 11-16-2015, 08:22 PM
My OEM S fronts looked like this:
1972 914/4 Race Car
Old 11-16-2015, 08:43 PM
-C
S is a one piece aluminum caliper, A is a multipiece bolted up iron caliper
Both use the same 3.5" mounts and 20mm rotors
Bill Verburg
Old 11-17-2015, 03:20 AM
bgyglfr's Avatar
Definitely an A front caliper.
70T 2.7RS spec.
68L coupe
Old 11-17-2015, 04:36 AM
Ah yes, too tired last night. Yes, iron unit. Still, Bilstein struts = excellent set up.
-C
1972 914/4 Race Car
Old 11-17-2015, 07:50 AM
Thank you guys for the input and for the help!
Old 11-17-2015, 02:08 PM
