Tcrate's Avatar
Front Control Arm and Bushing Angles
I have done a lot of searches on Pelican but cannot find the answer for this . Is there an answer to what angles these two bushings should be set at? I stole this photo from an earlier post. I am asking in regards to a 1976 911. Thanks.
Tom
1987 911 Targa
1987 944 Turbo
1976 911S
1973 Mustang Mach 1 351C
Old 02-07-2016, 04:30 PM
Can't remember but I think it is approx 30 degrees...hold on a bit and I will find it for you. Been about 6 years since I did mine.
1986 3.2 Carrera
Old 02-07-2016, 04:45 PM
A Arm Bushing
1986 3.2 Carrera
Old 02-07-2016, 04:48 PM
Tcrate's Avatar
Thanks Ben,
Any idea on the rear, I saw one thread that suggested maybe 15-16.
Tom
1987 911 Targa
1987 944 Turbo
1976 911S
Old 02-07-2016, 04:49 PM
I think rear is 20 degrees.
I used this video when I did mine from Elephant.
Front control
1986 3.2 Carrera
Old 02-07-2016, 04:58 PM
911 Spring Plate Angle Calculator
1986 3.2 Carrera
Old 02-07-2016, 05:04 PM
Tcrate's Avatar
Ok based on the elephant racing video it looks like the rear is 15-16 degrees and the Front is 20. The other thread you noted was showing 32-37 degrees on the front but the rear is 30 degrees but that does not look like it has the arm to the ball joint at zero so I am going to confirm those numbers but I am inclined to use the elephant racing angles. Thanks for the input. The spring plate calcs are going to help also.
Tom
1987 911 Targa
1987 944 Turbo
1976 911S
Old 02-07-2016, 05:26 PM
Yeah, I remember getting a lot of conflicting info when I did mine...I went with the Elephant video and had no problems with reassembly.
Good luck!
1986 3.2 Carrera
Old 02-07-2016, 05:42 PM
Tcrate's Avatar
Cool Thanks again. I took pictures too so I am going to compare with those once I get them on.
Tom
1987 911 Targa
1987 944 Turbo
1976 911S
Old 02-07-2016, 05:47 PM
Jase77's Avatar
Hi Tom,
I am currently at the rear of my car just finishing the strip down of the suspension and next up is the front. Unfortunately it may take me a few weeks to begin with but I will measure the angles on my car and let you know. I have some Superpro bushes to go on and was going to position them as per the Elephant Racing video anyway.
Not sure if you are doing the rear suspension too but I just tried the link (from Ben) to the spring plate angle calculator and it's accurate to mine which I just removed yesterday.
Good luck and keep us posted.
Jason
1994 968CS
1977 911S
1969 MGB GT
1958 Norton Dominator
Old 02-08-2016, 12:09 AM
Tcrate's Avatar
Thanks Jason,
Good to know I already printed out the rear spring angle plate calculations and plan on using that for my install.
I am anxious to here what your A Arm angles are. Thanks.
Tom
1987 911 Targa
1987 944 Turbo
1976 911S
Old 02-08-2016, 06:03 AM
Jase77's Avatar
Hey Tom,
Apologies for the delay but I have finally got onto the front end of my car and here are the angles of the brackets on my Control Arms.
What angle did you set yours to? I have Superpro bushes to fit and I cannot decide weather to set them to the figures from Elephant Racing or set them to these figures in the photos??
Hope the rest of your project went well?
Cheers,
Jason
1994 968CS
1977 911S
1969 MGB GT
Old 03-28-2016, 11:50 AM
I just did this a month ago and did lots of reading before hand. The general theme was to follow the ER video or paper instructions. I did this and the reassembly went well.
84 911 Targa Carrera currently getting renewed
Old 03-28-2016, 12:24 PM
Tcrate's Avatar
Jason
Thanks for the response. I would be inclined to go with the angles you came up which are close to the ER guidelines. I pretty much did that as well. I still need to set my ride height etc and see how all this lines up but I have a lot of work on the car to do before I get to that point. Thanks for the input.
Tom
1987 911 Targa
1987 944 Turbo
1976 911S
Old 03-28-2016, 12:30 PM
prschmn's Avatar
Bushings
I have always installed factory type rubber bushings at the angle they will
be at when the car is at ride height. This way they aren't constantly tourqued.
Curious why anyone would put preload into them?
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 03-29-2016, 04:31 AM
Tcrate's Avatar
Mark,
That makes a lot of sense I guess the question is what are those angles for a stock setup? Do you know.
Tom
1987 911 Targa
1987 944 Turbo
1976 911S
Old 03-29-2016, 09:21 AM
prschmn's Avatar
Angles
I'm assuming-not always good- that we are dealing with stock type
bushings here and that you likely not going to vulcanize them back
on the arms which gives some fudge factor.
At a Euro ride height the arms are nearly horizontal so just install the bushings
accordingly Since they aren't bonded they will slowly creep to there
happy zone.
Mark
Old 03-29-2016, 10:57 AM
