Reference Sensor Testing
I have been looking at information on how to test my reference sensors in my 1984 Targa. I saw the clip on YouTube where he does the test on the plug to the ECU.
Do I have to test there? Or can I test from the engine compartment as well?
My search did not provide any concrete answers.
Thanks.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 11-30-2015, 08:37 AM
Undocumented User
McLaren-TAG's Avatar
I know it's not the technical answer you're looking for but after much trials and tribulations in my chasing a no start while warm issue.
When the car is cold, If you heat up the area of the sensors with a heat gun to operating temp, you'll duplicate the no start when warm issue.
Old 11-30-2015, 08:59 AM
Unplug both black plugs and measure around 1000 ohms resistance between the bottom two of the 3 terminals of each black plug, on the engine side of course.
206 637 4071
Old 11-30-2015, 09:21 AM
Thanks, John Walker! I knew I could do it from there, but was not sure.
You just saved my back!
Old 11-30-2015, 10:31 AM
OK, I got out this weekend and tested my sensors. They each were at 986, which is well within tolerance.
Next, I will try my ECU in my buddies car.
And I also have set out to remove the UNGO box from my car. Good lord! Where do some of these wires go???
Old 12-07-2015, 06:09 AM
Why are you testing your flywheel sensors?
Old 12-07-2015, 07:34 AM
No-start issue.
Old 12-07-2015, 10:03 AM
I had a no start hot engine problem. Sensor resistance checks at cold and hot condition showed correct resistance amounts (per Bentley). Replaced both sensors, no further start problems. See my postings last week.
Old 12-07-2015, 10:18 AM
Undocumented User
Hence the real world test recommendation ^^ up there.
Old 12-07-2015, 11:20 AM
steely's Avatar
If this is the same problem you had in June, I'd replace the sensor - that is, if your fuel pump stopped firing.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 12-07-2015, 06:05 PM
Diss Member
Quicksilver's Avatar
To completely test the sensors you need to get an oscilloscope, crank the engine, and see what kind of voltage the pulses have. It should be 2.5 volts. If you aren't getting that much you should look at the gap between the sensors and the teeth/pin on the flywheel.
BTW "Fun Fact" - If the reference sensor has no pulse when the TDC pin goes by check the pin with a magnet. John Walker found a flywheel that had been made with a stainless pin!
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 12-07-2015, 09:05 PM
gwinnch's Avatar
I have a similar issue with my '85, need some help on testing my sensors:
I get a good resistance reading at each sensor for terminals 1/2 but get nothing in any meter setting for 1/3 and 2/3. Bentley says these two pairings should read greater than 100,000 ohms, so does that mean mine are over 2M ohms, or bad?
1985 911 Targa
2001 996 C2
2009 997 C4S
Old 12-14-2015, 10:16 AM
Is that nothing the same nothing your meter reads when you measure high resistance, like with the probes laying on the table not touching anything? If so your resistance tests have passed.
Rick
88 Cab
Old 12-14-2015, 10:28 AM
Yes, Steely, I am not the fastest repair guy out there. I got sidetracked with motorcycles and the new Lotus Europa, so progress has been slow.
This week, we are going to remove my ECU and try it in my friend's car.
Hopefully, it will prove bad, and then I could ship it out to Ingo for some TLC.
Old 12-14-2015, 11:17 AM
gwinnch's Avatar
Rick, it doesn't change when I hit it with the probes, so same as when probes are on the bench not touching anything or each other. I put some heat on it and the resistance at 1/2 goes up to 1200-1300 then goes back to about 960 cold. Is that a problem?
Chris, not trying to hijack your thread-thought this would be useful to both of us! Thanks!
1985 911 Targa
2001 996 C2
2009 997 C4S
Old 12-14-2015, 11:45 AM
No worries, it's all good.
I am in the middle of bumbling my way thorugh so I'll read anything.
Old 12-14-2015, 11:49 AM
gwinnch's Avatar
Finally got time to get back to my no start issue:
Went ahead and replaced my ref sensor with the less expensive bmw part-it started right up. New and old sensor meter at the same values...
1985 911 Targa
2001 996 C2
2009 997 C4S
Old 12-27-2015, 09:24 AM
