Automotive vinyl hairline cracks- brand new
I don't tend to have the greatest luck, for those that know my story.
Anyway, the latest in my saga is that I got some dark brown automotive vinyl for my 911, but every eight inches or so, there is a loose line across the vinyl of interspersed tiny cracks in the vinyl. You can only see them in the correct light at viewing angles of about 70 degrees or more. I have covered one RS door panel with it, so when the doors are open, they don't look great. They look fine from straight on. See below. I am assuming I got a bad batch of vinyl. Thoughts? not bad ![]() looking good. ![]() Sunlight. On the right side you can kind of see the vertical lines. ![]() Awww crap...
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 12-06-2015 at 07:57 PM.. |
hairline cracks
I believe the sheet was folded for a long time ....maybe it can be ironed from its back side.
That is what I thought. Thing is, the entire roll has the same lines in the same rough spacing. I just can't visualize that being due to folding given this it happens every 6 or so inches. You can kind of see four vertical lines of the repeating pattern below the window switches in the second to last photo.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS |
Rescuer of old cars
The brown vinyl I bought for my panels has nothing of the sort. I just got mine on today.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
That looks really slick Arne. I am going to get in contact with the upholstery shop that ordered me the vinyl.
Senior Advisor
wow, that is the best brown interior i have seen, i like!! sorry.
oh, and this will fix the cracking
08 Cayenne Turbo |
San Diego, CA
I think he was joking on the repair
Senior Advisor
08 Cayenne Turbo |
Designer King
The vinyl may have been rolled and then stored flat for a long time, causing the cracking to appear at the same interval as it bends around the flattened shape.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Counterclockwise?
Ya. I'd say rolled up and then weight was put on it.
But having said that, was there a cardboard core inside it to stop this from happening?
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
