Send a message via AIM to sempaipaul
Dropping engine... how much space needed to slide it out from under the car?
Title says it all
Trying to buy the correct jack stands and also figure out my strategy.
I was trying to get one of these:
500 lb. Capacity Hydraulic Table Cart
Take off the handle and place it under the engine. Drop the engine on it and then roll this thing out from under the car. I need to know how much clearance however the engine needs. I assume the bumper will have to come off?
The reason I want to use this cart is that I will have to load the engine into an SUV or a pick up for delivery to my rebuilder.
Any other alternative ideas that you guys have approached this with?
Thank you,
Paul
03' Audi RS6; 16' 328i xDrive Touring; 13' X3 mSport, 91' e30 M52
Old 12-08-2015, 04:57 AM
Three feet maybe more. AND THE CART HEIGHT PLUS THE ENGINE PLUS SOME MORE TO BE SURE.
Old 12-08-2015, 05:18 AM
I have a 1979 Carrera SC by the way
Old 12-08-2015, 05:25 AM
I like 6 ft behind the car but I'm using a jack with full handle.
Bruce
Old 12-08-2015, 06:03 AM
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
I never measured the height needed... but I can tell you that those carts are great for getting the engine and tranny out!
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 12-08-2015, 06:15 AM
notfarnow's Avatar
about yay high
'03 Carrera 4s
+ a whole bunch of boats
Old 12-08-2015, 06:16 AM
Undocumented User
McLaren-TAG's Avatar
So is a two post lift.
Old 12-08-2015, 06:17 AM
wachuko's Avatar
Absolutely. I jumped at the first batch of these when they came out. Having a low ceiling garage and not able to install a normal two-post lift... this Max-Jax has been excellent.
Drive safe!
1967 - Porsche 912
Old 12-08-2015, 07:11 AM
notfarnow's Avatar
They are the cat's ass for those of us with small, or low garages. I couldn't have a 2 post lift installed permanently in my small garage, and I love the idea of having mounting plates located in different spots in the garage.
'03 Carrera 4s
Old 12-08-2015, 07:18 AM
Mick_D's Avatar
I removed the lower valance and bumper w/extensions and raised the car at least 22.5 inches , measured at the bottom of the torsion bar covers, where hopefully you have the stands.
Old 12-08-2015, 07:23 AM
I put my engine on a modified Harbor Freight furniture cart, maybe 6" tall total. Couldn't get it to clear what I felt was safely with the bumper on, I ended up pulling the bumper. I used 3 ton SUV jack stands which go to about 16" tall. Memory is a little fuzzy, but I don't think those were high enough on the torsion bar covers, even with the bumper off.
Matt - 84 Carrera
Old 12-08-2015, 08:00 AM
wayner's Avatar
How many other internet car forums have so many members sharing pictures of dropping perfectly functional engines just for fun?
SOLD - 914 wide body hot rod
Old 12-08-2015, 09:17 AM
Complete CIS engine clearance removal........
Paul,
The height of the complete CIS engine from heat exchangers to top of the CIS boot is approximately 28". So you would need a minimum of 28" + cart height. In your case it could be 28" + 8"(?). Add another inch for additional clearance. Removal of the rear valance would lessen how much you have to raise the car. Whatever you do, stay safe and make sure the car is stable before pulling the engine. Loosen the four (4) mounting bolts prior to getting to the required height for clearance.
Tony
Old 12-08-2015, 09:38 AM
Topless crazy
seanratpel's Avatar
36"
Old 12-08-2015, 09:41 AM
Runnin on empty
acme911's Avatar
Not certain, but believe there were other threads recommending the 1000lb version of that cart as it was a little weak on the the lifting.
Originally Posted by sempaipaul View Post
Title says it all
Thank you,
Paul
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITB’s, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff.
https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html
Old 12-08-2015, 10:58 AM
wachuko's Avatar
Thumbs up
Good catch. Correct. Need to go with the 1,000 version. That is the one I got. When you consider both engine and transmission best to go with the higher rate version.
Drive safe!
1967 - Porsche 912
Old 12-08-2015, 11:02 AM
After the motor is on the cart, you can use 2x6 under the body near torsion tubes and use your floor jack to lift the now lighter body high enough to slide out and then rest back on jack stands after its out..
Dave
1985 Factory Turbo-Look Coupe
2011 Cayman S
2012 Audi S4
Old 12-08-2015, 11:09 AM
wdfifteen's Avatar
This is my poor-man's lift. I drive the car onto my trailer, put the ramps up on jack stands, and back the car onto the ramps. I should have, but I didn't measure the height of the car when I was getting the engine out. I think it was about 30", which included 5 inches for the transmission jack. Because the car was sitting on its suspension it raised up about 3" when I disconnect the engine/transmission mounts. The engine and trans weight about 650 lbs, so a 500 lb jack isn't going to cut it. I use an 800lb Harbor Freight transmission jack and it wasn't enough.
Old 12-08-2015, 11:52 AM
Brew Master
cabmandone's Avatar
I used a craftsman ATV jack to drop my engine. The most recent time I left the bumper on and I'm thinking my rear valance was about 36" off the ground. On my 3.2 I removed the filter box and elbow to give myself the necessary clearance. I had my rear jack stands as high as they'd go plus a 2x10 under that. I then put jacks under the front to level the car and got the engine and trans loose and started lowering with the atv jack. I then went up front and lowered the front back down to the ground which put the back where you see it in the pics.
Old 12-08-2015, 12:32 PM
Mick_D's Avatar
I musta gotten lucky, I just raised the car as high as I could with the floor jack on the sump, put it on stands at that height, took the bumper and valence off, and I had more than enough room. I dropp the motor and trans with the floor jack to a furniture dolly. Will be putting the engine on a stand soon. I bet that's harder than lowering it in one piece.
Old 12-08-2015, 12:37 PM
