LED Update and Question
I have recently become obsessed with replacing all of the bulbs in my 911 with some sort of LED replacement. I think it's because I feel like 'modernizing' everything about the car but the looks, if that makes sense.
First, I installed LED gauge lights by a forum member named rothaus that made an incredible difference. (a tutorial on how I did it is at LED Gauge Tutorial)
Next, I replaced all the interior lights with EBay LED bulbs and installed under dash lighting (see New Interior Lights)
Then, I bought spoke's LED brake lights, which made an incredible difference and will probably decrease the likelihood that I'll be rear-ended by a text-messaging soccer mom with 5 kids in her van.
Today, I replaced the reverse lights with these bulbs I got on EBay:
And the result is pretty dramatic:
So, here's the question:
I tried installing LEDs for the turn signal bulbs, but when I did, they began flashing at double-speed like they do if you remove the bulb completely. The lights worked and were nice and bright, but they blinked way too fast. I'm sure it has something to do with a voltage drop or something.
Is there a way around this so I can still use LED bulbs?
1986 911 3.2 Cabriolet
"We all have a desire to create something that will show we were here. " Ferry Porsche
Old 12-11-2015, 03:13 PM
I should add that in the picture, the new reverse light is only installed on the right side for comparison.
Old 12-11-2015, 03:14 PM
There is a solid state flasher EP 36, that will work with LED's or incandescent, I got mine from Amazon:
http://www.amazon.com/gp/product/B00064LQLC?psc=1&redirect=true&ref_=oh_aui_search_detailpage
You will need to ground the common wire connecting the indicator bulbs in the tachometer, on mine it is blue/white.
Search the LED Brae lights thread. You will find this and other info, including the effect on the cruise control
Good luck,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 12-11-2015, 03:21 PM
I have just put in Spoke's backlights/brake lights- really good!
I have tried to instll some LED replacement reversing lights but not a good fit- can you send me the ebay link for yours?
Clive
Old 12-11-2015, 04:27 PM
Sure, it turns out those were from Amazon. Here you go:
http://www.amazon.com/gp/product/B00OGXID7E?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
Old 12-11-2015, 05:05 PM
Also, I forgot to mention that the seating little pins were offset on the LEDs but were even on the original bulbs, so they wouldn't go in easily. I took a Dremel tool and ground down the uppermost pin a little and then they fit fine.
Old 12-11-2015, 05:08 PM
Phillips makes a replacement bulb for the directioanals that doe not require a flasher replacement.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 12-11-2015, 05:12 PM
RSTarga, you don't happen to know a part number or link for it do you?
Old 12-11-2015, 06:24 PM
spoke's Avatar
Peter,
Hyperflashing is a safety feature built into most car's flasher relay. The flasher is designed to flash at 2x rate (hyperflash) when the loading is less than the wattage of 2 normal bulbs. Normal bulb is about 20W. So 2 bulbs burn about 40W.
If the flasher senses something like 30W or less, it will hyperflash to alert the driver that a bulb is burned out. LED replacements burn much much less, maybe 3W to less than 10W. To replace front or rear or both with LEDs requires a change to an LED-compatible flasher.
As Dave mentioned, the EP36 is LED-compatible and plug-in compatible with the 911 standard flasher. Every FLAPS that I've checked (Pep Boys, Autozone, Advance Auto, etc.) carry EP36 on the shelf for around $15.
Old 12-11-2015, 06:31 PM
Thanks spoke! I figured the voltage difference was the issue. I'll definitely try the EP36. I'm assuming that would be needed with your turn signal LEDs anyway, right?
Old 12-11-2015, 06:40 PM
spoke's Avatar
Yes, my turnsignal boards burn about 5W each. When I did the first one, I realized I needed an EP36. Really annoying when turnsignals hyperflash. I've seen this a lot in work trucks when turnsignals are replaced with LED types.
The flasher is behind the dash. I found mine by going through the front trunk. It helps to have the turnsignals or 4-ways on and just follow the clicking sound. Replacement took about 1 minute.
Old 12-11-2015, 06:44 PM
Thanks spoke! I figured the wattage difference was the issue.
What you meant...
Might be easiest to replace the flasher by reaching through a gauge hole.
Old 12-12-2015, 05:03 AM
Ahh, sorry. That makes sense--I guess it's 12 volts all the time, isn't it.
My electrical experience is limited to the Alabama multimeter--if you touch a 9 volt battery to your tongue and it tingles, it's probably good, if you touch a lawnmower spark plug while it's running and your arm shakes, it's running fine, and if you touch a household wire and piss your pants, then it's a 110 line.
Old 12-12-2015, 05:35 AM
Wer bremst verliert
JohnJL's Avatar
And if you go #2 its 220v?
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 12-12-2015, 05:55 AM
Diss Member
Quicksilver's Avatar
Thanks spoke! I figured the amperage difference was the issue. I'll definitely try the EP36. I'm assuming that would be needed with your turn signal LEDs anyway, right?
What you meant...
What was was really, REALLY meant...
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 12-12-2015, 06:00 AM
Well, see, the wattage determines the amperage, given the voltage, divided by wwest's IQ, which is more math than I can do.
Maybe it's the impedance. Or the phase. Or the weight.
Old 12-12-2015, 06:14 AM
Diss Member
The reason you had to "ground down the uppermost pin" is you used the wrong type of bulb. The bulb you listed is a replacement for an 1157 which is a 2 filament bulb.
The backup lights use an 1156 which is only a single filament bulb so it doesn't need to be "keyed" with offset pins.
Try this one from the same supplier: http://www.amazon.com/SiriusLED-Bright-Projection-Signal-Brightness/dp/B0105LW41G/ref=sr_1_1?ie=UTF8&qid=1449929648&sr=1-1
It is a 35W equivalent and you will need to click the options for 1156 and white.
Old 12-12-2015, 06:26 AM
This thread should help you with your problem:
I solved the LED indicator problem!!
Old 12-12-2015, 12:39 PM
universeman's Avatar
I bought an EP35 and an EP36 and neither work with my SC -- seems there's a missing fourth Common (C) pin.
I think I need an EP26 according to some other threads I've been reading, those are a bit harder to find.
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 12-12-2015, 12:54 PM
spoke's Avatar
What is not working? Pin 31 is ground. Pin 49 connects to 12V and Pin 49a goes to the lights. These 3 are all that is needed to flash the external lights. The K/C/C2 4th pin is usually used to do something with the dash indicators.
EP26 and EP36 are almost identical. Both are available at your FLAPS.
The EP26 that I've purchased from Autozone had the 4th C terminal but it did not connect to anything. I took it apart to verify.
In 914's I've seen the 4th terminal labeled as K, C, and C2. In some, K would connect to ground and C/C2 would connect to 12V when the lights are flashed.
Old 12-12-2015, 03:01 PM
