Flares - a question from ignorance and curiosity
What is the difference in shape between '84-'89 Carrera flares, SC flares and midyear Carrera flares? Until I read someone's comment yesterday, I had no idea SC flares and late Carrera flares were any different. I have a good eye for surfaces, and if I had examples of the cars sitting next to each other and I could look at them in person, I could probably answer my question. But, y'know, my local Mart o' Carreras is closed
Perhaps it is too subtle to easily pick up in photos. I was just curious. I don't think I knew Carrera RS flares and Turbo flares were so different, but it was pretty obvious to me when I looked at the RS clone photos posted to the show-me-your-middie thread yesterday.
'80 SC Targa Avondale, Chicago, IL Last edited by Otter74; 12-11-2015 at 02:04 PM.. |
I've wondered this as well, I see reference to 7" or 9" flares and don't really know what they are referring to...maybe it's reference to the wheel size they are compatible with? Really don't know.
Good question.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
I always interpreted it as what size rim you'd need to be filling the wheel well properly under the flare. 7 inch flare requires a 7 inch rim, 9 inch needs a 9, 11 inch needs an 11, etc. DISCLAIMER: I reached this 'rule of thumb' conclusion on my own so I have no corroboration on it.
Try a search. This question has been addressed/answered many times.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
Bottom line, '73 Carrera RS and some early 2.7 Carrera flares have one shape, everything after that has a slightly different shape. The differences are in the shape of the opening and the profile of the fender lip.
JR |
Guest
Posts: n/a
I did this comparison about 100 years ago. The top is a 78 - 89 flair. Bottom is an RS/early Carrera flair. The lip turn down width is different.
from '64 not counting race and rally cars there have been only 4 basic fender sizes shorter w/b '64-68 6/6 wheels these cars came w/ almost slab sides and used 6" max wheel width longer w/b '69- 77 regular 6/6 wheels these cars have a bit more flare but still the same 6" max wheel widths oe though 7/7 could be fitted, These are often called 7" fenders '73-74 Carrera 6/7 wheels w/ 7/8 options, these have a 2" wider rear fender than above and can be fitted w/ up to 9" wheels in back, fronts are the same 7" flares as above rear would be 9" flares '75-89 SC & Carrera, 6/7 wheels, 7/8 option, these have the same fenders as above, the contour of the rears was subtly different in '73-74 but all accommodate the same 7 & 9" wheels '75 -89 930 7/8 & 7& 9 wheels, these have the very wide fenders similar to those seen on the '73 RSR, the RSR used 9 & 11" wheels, so the flared are called 9" front and 11" rear.
Plus a few more detail differences:
1965-1968 torsion bar hole placement was closer to the wheel well opening Short wheel base (swb) 69-86 torsion bar placement was the same dimension as 65-68 BUT the wheel well opening was a bit further away than the earlier cars as these models have the longer wheel base (LWB) 1987-1989 torsion bar opening is a larger semi circular panel with corresponding cut out on the flare in front of the wheel well opening. If backdating an earlier car (65-77) to RS inspired look, these flares are not desirable because of this large opening and cover 1989 (964)-1994 have the same shape as the other Carrera flares (not RS of course) but have an even larger opening and indentations for fastening the plastic "shark fin" covers of the 964 rocker set up
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
Thanks, Bill. This answers everything I was wondering about perfectly. Mark Wilson's photos above also make the difference from pre-'74 flares very obvious.
'80 SC Targa Avondale, Chicago, IL |
Black and Blue
and if i remember correctly...somebody posted a picture of the "Nature Boy" Rick Flair
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
