Ah yes, the benefits of twin plugging are obvious.
Tongue firmly in cheek
Chuck Moreland - elephantracing.com - vonnen.com |
Thanks Wayne, im putting a 3.6 in and was wondering why the dual distributor, my questions are answered, makes since, Kevin
Warren Hall Student
HP vs. Torque and the bicycle theory!
Hey Island,
I just thought of how your bicycle parallel relates to the difference between HP + Torque and why twin plugging helps more with torque than with horsepower. When pedaling a bicycle from a standstill you want to exert the most force you can from 12:00 o'clock on the pedal(piston) continuosly to 6:00 o'clock. This gives you torque. After you're moving at a clip the issue becomes staying in sync and feeding (flow) the pedals (pistons) to sustain the momentum or HP if you will. This is why flow is criticle to HP. Bobby
Oh my.
Information Junky
fishheads withstanding. . .Right, "spinning" (as the crowd soon to invade with bicycle manutia, will tell you) is the way to get HP to the road. You don't force the pedals nearly as hard as you could (torque). Instead, you put the forces in much more often (than when jumping on the pedals)
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Irrationally exuberant
-Chris |
Bobby - Your observation is profoundly sublime!
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
Just so Camb and I don't confuse people. CamB's method applies to pre 3.2 motors. A 3.2 just uses a "splitter box" to run a 2nd coil.
Uh yeah - sorry for confusing anyone (I actually had no idea the Carrera was so different - don't I look silly )
1975 911S (in bits) 1969 911T (goes, but need fettling) 1973 BMW 2002tii (in bits, now with turbo) |
