928s4 brakes on a 911sc?
What rotors do I need to run these calibers? Also will my 7 and 8 16 inch Fuchs work w these brakes?a company called VCI has the rotors to run this set up but r expensive. I already have the brackets to mount the calibers and a 23mm master cylinder. Where can I find rotors and what other problems will I run into? Thanks
Old 12-24-2015, 06:50 AM
Anyone using these brakes?
Old 12-24-2015, 09:45 AM
JMHO, based based on experience, you just cannot do this on the cheap.
Crap rotors shake the steering wheel right out of your hands and good rotors cost money.
My best counsel to you is to save your money until you can buy the right parts to finish the job.
You will need a 305x32mm rotor/hat assembly for the front to use those calipers. 951 Fuchs wheels are required for caliper clearance.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-24-2015, 09:54 AM
Kraftwerk's Avatar
Cool idea. Sounds expensive though, to do it right.
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 12-24-2015, 10:07 AM
I've got the right mounting brackets. Just need the front rotors to make it work
Old 12-24-2015, 11:01 AM
300hp 1800lbs is the goal
pksystems's Avatar
Wilwood 12.19 x 1.25 rotor with 1/4" hat.
993 brake conversion, source for rotor adapter
I have some pics of mine assembled in my garage, but my p-car project is on hold, so I haven't tested them. They bolted onto SC/Carrera struts/hubs and fit fine.
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 12-24-2015, 11:21 AM
I have the S4 calipers and Coleman rotors on the front of my 911, street driving and tracking the car. I followed the bedding procedure but had challenges with warping. When it comes time to replace I think a more "economical" route might be to use a stock 930 rotor with the appropriate hat. Although heavier, I think it would give a longer life with less warping issues. Anyone using this combo? And if so what rotors and who's hats?
Thanks,
Tinker
Old 12-24-2015, 01:00 PM
Bill Verburg's Avatar
Regular 911 Fuchs no, 951 Fuchs yes, barely
here's a set of 993 front w 304x32mm rotor in 952 Fuchs, I forget whether it's 7 or 8
other concerns are that you need a matching rear, 993 rears can be adapted to 911 trailing arms w/ 930 rear rotors, the calipers will need a little modification to fit.
Bill Verburg
Old 12-24-2015, 01:10 PM
