Originally Posted by sugarwood View Post
Are you saying you've never heard of this, or that it's not accurate?
https://youtu.be/BiW0ISi8N-w?t=44s
Its not accurate for a multitude of reasons.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-24-2015, 06:19 PM
ted ted is offline
likes to left foot brake.
ted's Avatar
Originally Posted by RDM View Post
So what would the recommended rebuild cycle be for Bilstein shocks on a street-driven car (years or miles)?
According to RE Suspension road race shocks need a rebuild every 3 or 4 years.
Replace oil and seals and sometimes the washer/shim stacks.
The oil eventually gets contaminated and that accelerates wear on seals and metal parts.
Apparently the thin metal washers/shim stacks in the shocks with time deflect and need to be replaced too.
Off road racers in extreme conditions do this a few times a season.
Production car shocks are said to last 50,000 miles. ymmv
A set of adjustable racing shocks that cost $2k to $4k+ that get rebuilt for $300 makes sense.
If you have less expensive shocks just replace them in pairs.
Old 12-25-2015, 08:01 AM
ted ted is offline
ted's Avatar
On other cars, it makes sense if the shock has no oil, there is no resistance, and a car will bounce on the coil springs when the spring decompresses.
The jounce is too random.
How much compression is in a good jounce?
I cant even jounce my race cars or 1 ton truck.
Old 12-25-2015, 09:07 AM
Are you road racing where custom-valved shocks are mostly used? If not, standard, HD or sport shocks should be enough options for most owners. However, as always, YMMV.
Sherwood
Old 12-29-2015, 01:13 PM
